| 0002048 | FreeCAD | Bug | public | 2015-04-11 04:58 | 2015-04-11 11:22 |
| Reporter | drei | Assigned To | wmayer | ||
| Platform | 64 bit | OS | Arch Linux | ||
| Summary | 0002048: FreeCAD crash when opening FCSTD file containing a spreadsheet | ||||
| Description | Opening the file ssMod2_example.FCStd posted here: http://forum.freecadweb.org/viewtopic.php?f=10&t=6360&start=110 generates a sigsev error and FreeCAD immediately crashes. | ||||
| Steps To Reproduce | Open FreeCAD either from terminal, menu or shortcut Open the file | ||||
| Additional Information | Terminal output: *** Abort *** an exception was raised, but no catch was found. ... The exception is:SIGSEGV 'segmentation violation' detected. Address 0 gdb output: Starting program: /home/isaac/Programs/Original/build/bin/FreeCAD [Thread debugging using libthread_db enabled] Using host libthread_db library "/usr/lib/libthread_db.so.1". FreeCAD 0.16, Libs: 0.16R4783 (Git) © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2015 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## [New Thread 0x7fff937fe700 (LWP 1542)] [New Thread 0x7fff92ffd700 (LWP 1543)] [New Thread 0x7fff93fff700 (LWP 1541)] [New Thread 0x7fff99ee4700 (LWP 1540)] [New Thread 0x7fff9ad1b700 (LWP 1539)] [New Thread 0x7fffdb61e700 (LWP 1538)] Program received signal SIGSEGV, Segmentation fault. 0x00007ffff639f47a in xercesc_3_1::ReaderMgr::peekNextChar() () from /usr/lib/libxerces-c-3.1.so (gdb) bt #0 0x00007ffff639f47a in xercesc_3_1::ReaderMgr::peekNextChar() () from /usr/lib/libxerces-c-3.1.so Backtrace stopped: Cannot access memory at address 0x7fffffffb9e8 FreeCAD info: OS: Linux Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.4783 (Git) Branch: master Hash: 6a6a3d3bd05144e910741c88491f86bf0142acea Python version: 2.7.9 Qt version: 4.8.6 Coin version: 3.1.3 OCC version: 6.8.0.oce-0.17 attachment: file that causes crash | ||||
| 2015-04-11 04:58 | drei | New Issue | |
| 2015-04-11 04:58 | drei | File Added: ssMod2_example.FCStd | |
| 2015-04-11 11:21 | wmayer | Status | new => closed |
| 2015-04-11 11:21 | wmayer | Assigned To | => wmayer |
| 2015-04-11 11:21 | wmayer | Resolution | open => duplicate |
| 2015-04-11 11:21 | wmayer | Fixed in Version | => 0.15 |
| 2015-04-11 11:22 | wmayer | Resolution | duplicate => fixed |
| 2015-04-11 11:22 | wmayer | Changeset attached | => FreeCAD Master master c62319d2 |
