| 0000210 | FreeCAD | Bug | public | 2010-11-17 20:56 | 2010-11-24 16:42 |
| Reporter | magerbeton | Assigned To | wmayer | ||
| Summary | 0000210: arcs in cutouts are put to svg with reversed sense | ||||
| Description | Arcs in cutouts are saved to svg (via "insert view in drawing") sometimes with inverse polarity. The problem seems dependant on the center-axis of the arc in world coordinate system and therfore the projection for put-to-svg. It has been seen in convex arcs on outer contours too, but this case is difficult to reproduce. Build 3724 | ||||
| Additional Information | Reproduction is easy: create box, create second smaller box, fillet edges of smaller box. Subtract small box from big box so that something like a box with a hole with round corners results. create a drawing page put to drawing Inner arcs are under some unknown conditions sometimes with wrong sign. The same has been seen for concave outer arcs too. This inversion can happen to any kind of arc in a cut-out. If a copy of the same object is rotated 90 deg around x,y or z in world ccordinates and is then re-exported (and the viewing direction is adjusted accordingly) the problem will come or go. | ||||
| 2010-11-17 20:56 | magerbeton | New Issue | |
| 2010-11-17 20:56 | magerbeton | File Added: svg_arc_exportbug.FCStd | |
| 2010-11-24 16:42 | wmayer | Note Added: 0000438 | |
| 2010-11-24 16:42 | wmayer | Assigned To | => wmayer |
| 2010-11-24 16:42 | wmayer | Status | new => closed |
| 2010-11-24 16:42 | wmayer | Resolution | open => fixed |
