| 0002104 | Draft | Bug | public | 2015-05-15 14:40 | 2015-12-15 13:15 |
| Reporter | bejant | Assigned To | yorik | ||
| Summary | 0002104: Draft WB Grid Shifts To Center Of Mass When Fixed To Plane | ||||
| Description | The Draft WB grid shifts to center of mass not only when set to Auto but when fixed to a plane. This ticket was filed per Yorik's request. | ||||
| Steps To Reproduce | The discussion is here: http://forum.freecadweb.org/viewtopic.php?f=3&t=10899#p87995 and a file is in the post just before that one. | ||||
Thanks bejant! |
I looked into this a little deeper. When the object is selected alignToFace in WorkingPlane.py calls self.alignToPointAndAxis(shape.Faces[0].CenterOfMass, shape.Faces[0].normalAt(0,0), offset) which centers the working plane on the object. That makes sense. The problem is in DraftTrackers.py where gridTracker then uses the plane position to draw the grid without snapping the position. Changing this fixes the display of the grid, I haven't found the similar code for grid snapping (instead of display). |
| 2015-05-15 14:40 | bejant | New Issue | |
| 2015-05-16 03:10 | yorik | Assigned To | => yorik |
| 2015-05-16 03:10 | yorik | Status | new => assigned |
| 2015-05-16 03:10 | yorik | Note Added: 0006142 | |
| 2015-05-26 08:43 | TomGoBravo | Note Added: 0006161 | |
| 2015-12-04 01:00 | yorik | Changeset attached | => FreeCAD Master master fd191b80 |
| 2015-12-04 01:00 | yorik | Status | assigned => closed |
| 2015-12-04 01:00 | yorik | Resolution | open => fixed |
