| 0002140 | FreeCAD | Bug | public | 2015-06-01 20:20 | 2015-12-15 13:18 |
| Reporter | stephane.magnenat | Assigned To | ickby | ||
| Summary | 0002140: Intersection operation does not work | ||||
| Description | Intersecting two objects does not produce the geometrically-correct result. | ||||
| Steps To Reproduce | Load the attached file, use the intersection tool, see the result. | ||||
| Additional Information | These objects were created by loading SVG and extruding them, maybe this leads to broken objects. | ||||
The imported geometry fa-path is broken as it does have a non-closed outer wire. This makes the face non-valid. Check this via python console via >>> obj = App.ActiveDocument.getObjectsByLabel('fa-path')[0] >>> obj.Shape.isValid() False >>> obj.Shape.OuterWire.isClosed() False This makes the extruded solid invalid and lead to the failed boolean operation. Please fix the imported path. Note that FreeCAD uses 1.e-7 as default tolerance for coincidence detection. If your svg works with lower precision consider increasing the edge and vertex tolerance of the wire before making a face from it. I'm closing this issue as a boolean operation has undefined behaviour on broken input data, hence this is not a bug. |
| 2015-06-01 20:20 | stephane.magnenat | New Issue | |
| 2015-06-01 20:20 | stephane.magnenat | File Added: intersection-bug.fcstd | |
| 2015-06-02 05:53 | ickby | Note Added: 0006179 | |
| 2015-06-02 05:53 | ickby | Status | new => closed |
| 2015-06-02 05:53 | ickby | Assigned To | => ickby |
| 2015-06-02 05:53 | ickby | Resolution | open => fixed |
