0002143DraftBugpublic2015-06-05 14:22
Reportermeneldur Assigned Toyorik
PlatformLinuxOSFedora WorkstationOS Version21
Product Version0.15
Fixed in Version0.16
Summary0002143: Draft workspace crashes FreeCAD
DescriptionWhenever I choose "Draft" workspace, the application stops responding and after 3-5 seconds it crashes.
Steps To ReproduceStart app, choose Draft from dropdown menu.
Additional Informationhttps://bugzilla.redhat.com/show_bug.cgi?id=1227162
yorik
2015-06-03 01:22
administrator   ~0006182
Could you paste the info from menu Help->About FreeCAD->Copy to clipboard? Thanks
meneldur
2015-06-04 03:58
reporter   ~0006189
OS: Linux
Version: 0.15.$WCREV$
Python version: 2.7.8
Qt version: 4.8.6
Coin version: 3.1.3
yorik
2015-06-04 16:15
administrator   ~0006190
This looks like a pivy problem... Could you try the following?
1) start freecad from a terminal, so you get error messages when it crashes
2) in the freecad python console (menu View->Views->Python Console), enter these lines:
from pivy import coin
coin.SoCube()
If it crashes, then there is likely a problem with the pivy module on fedora...
meneldur
2015-06-04 22:18
reporter   ~0006191
Thanks for your support.
Yes, it crashed right after importing coin (couldn't invoke SoCube()).
This is the error:
FreeCAD: SoType.cpp:730: SbBool SoType::isDerivedFrom(SoType) const: Assertion `!this->isBad()' failed.
Aborted (core dumped)
meneldur
2015-06-04 23:14
reporter   ~0006192
Updated pivy from 5.0.8 from F21 to 5.0.10 from F23 repos.
Problem solved.
yorik
2015-06-05 14:22
administrator   ~0006193
The bst bugs are the bugs that solve themselves :)
Thanks for the follow-up!
2015-06-02 22:26 meneldur New Issue
2015-06-03 01:22 yorik Note Added: 0006182
2015-06-04 03:58 meneldur Note Added: 0006189
2015-06-04 16:15 yorik Note Added: 0006190
2015-06-04 22:18 meneldur Note Added: 0006191
2015-06-04 23:14 meneldur Note Added: 0006192
2015-06-05 14:22 yorik Note Added: 0006193
2015-06-05 14:22 yorik Status new => closed
2015-06-05 14:22 yorik Assigned To => yorik
2015-06-05 14:22 yorik Resolution open => no change required
2015-06-05 14:22 yorik Fixed in Version => 0.16
