| 0000216 | FreeCAD | Feature | public | 2010-11-29 13:22 | 2011-10-15 08:24 |
| Reporter | codeasylum | Assigned To | wmayer | ||
| Summary | 0000216: FreeCAD hangs on various operations | ||||
| Description | FreeCAD hangs when creating the first item on a empty project. Open FreeCAD. Click New. Click create a sphere. --> FreeCAD hangs on 99% CPU with steadily increasing memory until kill. Revision 3729. Has strong similarities with 3108976 | ||||
| Additional Information | codeasylum said: You're right. It was the "maximum deviation". Wouldn't it be nice to have this value saved in the file too, so you can have various files with various "maximum deviation" settings ? | ||||
Ah I think I got it. In the preferences under Part design > Shape view what is the value of the parameter "Maximum deviation depending on the model bounding box". By default this value is set to 0.2% which is a good trade-off. In case you have set to to something very small the problem is that the tessellation algorithms generate a huge number of triangles which causes the hanging. |
n this context it was suggested to have a Deviation parameter per object so that the objects can have individual deflections. This is now implemented with 5027. |
| 2010-11-29 13:22 | wmayer | New Issue | |
| 2010-11-29 13:23 | wmayer | Note Added: 0000442 | |
| 2010-11-29 13:23 | wmayer | Reporter | wmayer => codeasylum |
| 2010-11-29 13:24 | wmayer | Assigned To | => wmayer |
| 2010-11-29 13:24 | wmayer | Status | new => assigned |
| 2010-11-29 13:24 | wmayer | Additional Information Updated | |
| 2011-02-13 18:21 | yorik | Relationship added | parent of 0000266 |
| 2011-02-13 18:22 | yorik | Relationship deleted | parent of 0000266 |
| 2011-10-15 08:24 | wmayer | Note Added: 0001158 | |
| 2011-10-15 08:24 | wmayer | Status | assigned => closed |
| 2011-10-15 08:24 | wmayer | Resolution | open => fixed |
| 2011-10-15 08:24 | wmayer | Category | Bug => Feature |
| 2011-10-15 08:24 | wmayer | Fixed in Version | => 0.12 |
