| 0002162 | Draft | Bug | public | 2015-06-17 20:52 | 2015-12-15 13:15 |
| Reporter | Sage Brush | Assigned To | yorik | ||
| Platform | Mac | OS | OSX | OS Version | 10.8.5 |
| Summary | 0002162: Error When Importing DXF File | ||||
| Description | When importing attached DXF, the following error is reported: Traceback (most recent call last): File "<string>", line 1, in <module> File "/Applications/FreeCAD.app/Contents/Mod/Draft/importDXF.py", line 1471, in open processdxf(doc,filename) File "/Applications/FreeCAD.app/Contents/Mod/Draft/importDXF.py", line 1278, in processdxf x2 = float(rawValue(dim,13)) <type 'exceptions.TypeError'>: float() argument must be a string or a number The file does get imported and the resulting geometry is usable. | ||||
| Steps To Reproduce | Select: File > Open Select attached file in dialog box Click Open in lower corner of dialog box After a few seconds, the error is displayed at the bottom of the main program window | ||||
| Additional Information | Version of importer files: 0.38 Source: https://github.com/yorikvanhavre/Draft-dxf-importer | ||||
Hm it seems that diameter dimensions are not supported yet by the importer. I'll add that ASAP. In the meantime I fixed it so at least it doesn't give an error. |
FreeCAD: master 8c222a8c 2015-08-05 04:50:33 Details Diff |
Draft: small bugfix - issue 0002162 |
Affected Issues 0002162 |
FreeCAD: master 1da0ec65 2015-12-05 19:50:30 Details Diff |
Draft: added radial & diameter dim support to DXF import - fixes 0002162 |
| 2015-06-17 20:52 | Sage Brush | New Issue | |
| 2015-06-17 20:52 | Sage Brush | File Added: AF COUPLER assy R12.dxf | |
| 2015-08-05 02:50 | yorik | Changeset attached | => FreeCAD Master master 8c222a8c |
| 2015-08-05 02:51 | yorik | Note Added: 0006275 | |
| 2015-08-05 02:52 | yorik | Assigned To | => yorik |
| 2015-08-05 02:52 | yorik | Status | new => assigned |
| 2015-12-05 18:50 | yorik | Changeset attached | => FreeCAD Master master 1da0ec65 |
| 2015-12-05 18:50 | yorik | Status | assigned => closed |
| 2015-12-05 18:50 | yorik | Resolution | open => fixed |
