| 0002165 | Arch | Feature | public | 2015-06-22 10:40 | 2016-01-19 02:06 |
| Reporter | Johnny Geling | Assigned To | yorik | ||
| Summary | 0002165: Extend GUI for facebinder command | ||||
| Description | The GUI of the Facebinder command has the ability to select faces at creation. The Python command has the ability to change teh facebinder 'face' property. Having this command available in the GUI is a good extension of the command and makes the command even more usefull. With the GUI command is should be possible to see the selected faces. Should be highligthed. Faces must be deselectable and new faces must be able to add to the feature. The command can also be usefull outside the arch module, for surface modeling. See also discussion in forum : http://forum.freecadweb.org/viewtopic.php?f=3&t=11340 | ||||
| 2015-06-22 10:40 | Johnny Geling | New Issue | |
| 2015-06-22 13:28 | yorik | Assigned To | => yorik |
| 2015-06-22 13:28 | yorik | Status | new => assigned |
| 2015-12-16 17:31 | yorik | Changeset attached | => FreeCAD Master master 43e0083c |
| 2015-12-16 17:31 | yorik | Status | assigned => closed |
| 2015-12-16 17:31 | yorik | Resolution | open => fixed |
