| 0002169 | FreeCAD | Bug | public | 2015-06-24 06:46 | 2015-12-15 13:17 |
| Reporter | diorcety | Assigned To | |||
| Platform | Windows | OS | Windows 7 | ||
| Summary | 0002169: My project is stuck, i can't do anything on it | ||||
| Description | I have started a small project on FreeCAD(i'm not an expert). But after sometimes i can't do simple action. When i change something the object have a blue tick icon "Touched (but must be executed)". | ||||
| Steps To Reproduce | I create sketch Add a rectangle leave the sketch And try to pad it. "None of selected sketches/2D objects is valid for padding..." | ||||
It's a circular dependency problem. Same as here: http://forum.freecadweb.org/viewtopic.php?t=11135 Terminal shows: Document::recompute: The graph must be a DAG. Document::recompute: The graph must be a DAG. Document::recompute: The graph must be a DAG. Deleting "Sketch corp module alimentation" solves the problem, but it would be nice to tell user what's the problem. |
Many thanks. I deleted the Fillet0001 and now it works. Indeed tell the user the issue should be great. But at first i don't understand what i did to fall in this issue. |
Closing this because there is no bug here... |
| 2015-06-24 06:46 | diorcety | New Issue | |
| 2015-06-24 06:46 | diorcety | File Added: test.FCStd | |
| 2015-06-25 21:33 | pfirszt | Note Added: 0006229 | |
| 2015-06-26 06:29 | diorcety | Note Added: 0006232 | |
| 2015-08-05 02:53 | yorik | Note Added: 0006276 | |
| 2015-08-05 02:53 | yorik | Status | new => closed |
| 2015-08-05 02:53 | yorik | Resolution | open => no change required |
| 2015-12-15 13:17 | yorik | Fixed in Version | => 0.16 |
