| 0002171 | Sketcher | Bug | public | 2015-06-25 12:18 | 2015-06-25 14:47 |
| Reporter | wmayer | Assigned To | abdullah | ||
| Priority | urgent | Severity | crash | Reproducibility | always |
| Summary | 0002171: Several issues when trying to delete an element of a sketch | ||||
| Description | After fixing a crash you will see that deleted elements still get rendered. Even a recompute (or the option to auto-recompute) doesn't fix this. You have to leave and re-enter edit mode to avoid to render them. | ||||
| Steps To Reproduce | As a test project get the attachment of this thread: http://forum.freecadweb.org/viewtopic.php?f=3&t=11508&p=92665#p92693 Open the project and enter edit mode of the sketch. Delete the top upper horizontal line (line 9). ==> Crash in ViewProviderSketch::updateColor() It crashes because the returned value of getSketchObject()->getGeometry(GeoId) (with GeoId = 15) is a null pointer. However, when fixing the crash by checking the returned value you will notice that the deleted element is still rendered. | ||||
| Additional Information | A different behaviour occurs when deleting e.g. the element line 4. In this case it crashes inside ViewProviderSketch::drawConstraintIcons() on the line > SoTranslation *translationPtr = static_cast<SoTranslation *>(sep->getChild(CONSTRAINT_SEPARATOR_INDEX_FIRST_TRANSLATION)); So, obviously the SoSeparator at this time doesn't have any children any more. | ||||
FreeCAD: master 21416961 2015-06-25 13:58:43 Details Diff |
Sketch: Bug fix: On delete crash with unsuccesful solving ========================================================== Fixes the one reported by JMG here (Thanks!!): http://forum.freecadweb.org/viewtopic.php?f=3&t=11508#p92693 Why? - The newly introduced redrawing policy requires that the solver geometry matches in number the sketchobject geometry. - Most (all) problems with updateColor or getGeometry returning a null pointer are related to an out of sync between UI geometry and SketchObject geometry. General solution: - In other bugs, a missing "solve()" is the problem, once the solver and sketchobject geometries have the same number, an SketchObject::OnChanged triggers a VPSketch::draw (via VPSketch::updateData) which updates the UI geometry to match SketchObject geometry and then the problem does not arise. Particular solution: - In this bug, the problem is not a missing solve, but the fact that the solving was not succesful and did not synchronize the geometries, however triggering a draw() on unsuccessful solving, syncronizes the UI geometry with the SketchObject geometry and the crash is gone. |
Affected Issues 0002171 |
FreeCAD: master cac47d25 2015-06-25 14:27:13 Details Diff |
Sketch: Bug Fix: Maintain the Elements and Constraint Widget synchronized ========================================================================= What? Sometimes this widgets where out of sync Why? Under the update only when it is redrawn policy, sometimes only one of them, i.e. the one associated with the property triggering the updateData was updated. Solution: Both are updated after every redraw. It also complements the previous bug fix related to crash on deleting, by updating the widgets to account for the deleted geometry. |
| 2015-06-25 12:18 | wmayer | New Issue | |
| 2015-06-25 12:18 | wmayer | Status | new => assigned |
| 2015-06-25 12:18 | wmayer | Assigned To | => abdullah |
| 2015-06-25 12:23 | wmayer | Reproducibility | have not tried => always |
| 2015-06-25 12:23 | wmayer | Steps to Reproduce Updated | |
| 2015-06-25 12:23 | wmayer | Additional Information Updated | |
| 2015-06-25 14:47 | wmayer | Changeset attached | => FreeCAD Master master 21416961 |
| 2015-06-25 14:47 | wmayer | Changeset attached | => FreeCAD Master master cac47d25 |
| 2015-06-25 14:47 | wmayer | Status | assigned => closed |
| 2015-06-25 14:47 | wmayer | Resolution | open => fixed |
| 2015-06-25 14:47 | wmayer | Fixed in Version | => 0.16 |
