0002180FreeCADBugpublic2016-01-08 16:05
Reportery_kulik Assigned Toabdullah
Platformx64OSUbuntu LinuxOS Version14.04
Product Version0.15
Fixed in Version0.16
Summary0002180: Edit Already Extruded Sketch
DescriptionReally Version 0.16
Imposible to select any Element on Editing Sketch
http://screencloud.net/v/cP1c
Steps To Reproduce1) Create one Sketch, Extrude it
2) Create other one, Extrude it.
3) try To edit first Sketch
Actual result:
 -- It is imposible to select some line of sketch by clicking on it, delete just threw left panel with called Elements(right click -> Del). Also Selected line not colored. it is also impossible to Create new constraints http://screencloud.net/v/3sp0 (on image i tryed to create "one point constraint" between two points that was choosen.)
Expected Result: Editing of sketch after apply some Part component should work as before apply something
abdullah
2015-07-20 04:01
manager   ~0006251
I can not replicate this problem (I mean, in general, I can create a sketch, pad it, create a second one, pad it and still edit the first one)
There may be a bug, but it may involve more specific steps.
If possible attach a file where this issue appears so that I can replicate it.
You might also want to post these issues in the help forum:
http://forum.freecadweb.org/viewforum.php?f=3
this would allow our power users helping there to narrow down the problem and help you provide a more specific bug report.
2015-07-03 15:51 y_kulik New Issue
2015-07-20 03:55 abdullah Assigned To => abdullah
2015-07-20 03:55 abdullah Status new => assigned
2015-07-20 04:01 abdullah Note Added: 0006251
2015-07-20 04:02 abdullah Note Edited: 0006251
2016-01-08 16:05 abdullah Status assigned => closed
2016-01-08 16:05 abdullah Resolution open => unable to reproduce
2016-01-08 16:05 abdullah Fixed in Version => 0.16
