| 0002180 | FreeCAD | Bug | public | 2015-07-03 15:51 | 2016-01-08 16:05 |
| Reporter | y_kulik | Assigned To | abdullah | ||
| Platform | x64 | OS | Ubuntu Linux | OS Version | 14.04 |
| Summary | 0002180: Edit Already Extruded Sketch | ||||
| Description | Really Version 0.16 Imposible to select any Element on Editing Sketch http://screencloud.net/v/cP1c | ||||
| Steps To Reproduce | 1) Create one Sketch, Extrude it 2) Create other one, Extrude it. 3) try To edit first Sketch Actual result: -- It is imposible to select some line of sketch by clicking on it, delete just threw left panel with called Elements(right click -> Del). Also Selected line not colored. it is also impossible to Create new constraints http://screencloud.net/v/3sp0 (on image i tryed to create "one point constraint" between two points that was choosen.) Expected Result: Editing of sketch after apply some Part component should work as before apply something | ||||
I can not replicate this problem (I mean, in general, I can create a sketch, pad it, create a second one, pad it and still edit the first one) There may be a bug, but it may involve more specific steps. If possible attach a file where this issue appears so that I can replicate it. You might also want to post these issues in the help forum: http://forum.freecadweb.org/viewforum.php?f=3 this would allow our power users helping there to narrow down the problem and help you provide a more specific bug report. |
| 2015-07-03 15:51 | y_kulik | New Issue | |
| 2015-07-20 03:55 | abdullah | Assigned To | => abdullah |
| 2015-07-20 03:55 | abdullah | Status | new => assigned |
| 2015-07-20 04:01 | abdullah | Note Added: 0006251 | |
| 2015-07-20 04:02 | abdullah | Note Edited: 0006251 | |
| 2016-01-08 16:05 | abdullah | Status | assigned => closed |
| 2016-01-08 16:05 | abdullah | Resolution | open => unable to reproduce |
| 2016-01-08 16:05 | abdullah | Fixed in Version | => 0.16 |
