| 0002197 | FreeCAD | Bug | public | 2015-07-22 14:30 | 2015-12-15 13:17 |
| Reporter | Valdas | Assigned To | wmayer | ||
| OS | KUbuntu | ||||
| Summary | 0002197: Buggy Placement dialog when using Euler angles | ||||
| Description | situation: - create cube in Part WB; - choose Edit -> Placement.. from menu; - in Dialog change method of Rotation to Euler Angles; - Roll change to -90 deg; - Pitch change to 45 deg; - hit OK in dialog; - inspect Placement property of Cube in Data tab: values are same as before Placement dialog (but cube visually is rotated); - try to change X value of Position property: visually rotation of cube resets to initial position. | ||||
| Additional Information | OS: Ubuntu 14.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.5238 (Git) Build type: None Branch: master Hash: fcefdc0a8dfecd63616b6445f91b20748ba390c9 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
I also experience this same issue when using the Transform GUI tool to rotate a part or setting the part placement using the Python console. I suspect the bug is in the property inspector GUI, as forcing it to "refresh" its information by selecting a different part and then reselecting the original part causes it to display the correct position information. |
FreeCAD: master 043dc161 2015-09-13 15:17:44 Details Diff |
+ fixes 0002197: Buggy Placement dialog when using Euler angles |
Affected Issues 0002197 |
| mod - src/Gui/PropertyView.cpp | Diff File | ||
| mod - src/Gui/PropertyView.h | Diff File | ||
| mod - src/Gui/propertyeditor/PropertyEditor.cpp | Diff File | ||
| mod - src/Gui/propertyeditor/PropertyEditor.h | Diff File | ||
| mod - src/Gui/propertyeditor/PropertyItem.cpp | Diff File | ||
| mod - src/Gui/propertyeditor/PropertyItem.h | Diff File | ||
| mod - src/Gui/propertyeditor/PropertyModel.cpp | Diff File | ||
| mod - src/Gui/propertyeditor/PropertyModel.h | Diff File | ||
| 2015-07-22 14:30 | Valdas | New Issue | |
| 2015-07-30 20:23 | biogeo | Note Added: 0006263 | |
| 2015-09-12 14:44 | wmayer | Relationship added | related to 0001941 |
| 2015-09-13 13:18 | wmayer | Changeset attached | => FreeCAD Master master 043dc161 |
| 2015-09-13 13:18 | wmayer | Assigned To | => wmayer |
| 2015-09-13 13:18 | wmayer | Status | new => closed |
| 2015-09-13 13:18 | wmayer | Resolution | open => fixed |
| 2015-12-15 13:17 | yorik | Fixed in Version | => 0.16 |
