| 0002198 | FreeCAD | Bug | public | 2015-07-25 09:46 | 2015-12-15 13:15 |
| Reporter | JMG_BT | Assigned To | yorik | ||
| OS | Linux Mint 17.2 Cinnamon 64bit | ||||
| Summary | 0002198: Draft interference with freehand placement | ||||
| Description | Freehand placement option ("transform" under right click menu) fails after activating Draft workbench. Workbench does not matter, because once you have activated Draft, "transform" will not work. OS: Linux Mint 17.2 Rafaela Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.5235 (Git) Build type: None Branch: master Hash: 6b3d7b17a749e03bcbf2cf79bbbb903137298c44 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
| Steps To Reproduce | 1- Open a new FreeCAD document 2- Switch to part design workbench and create a pad from a sketch 3- Switch to draft workbench and clone the previous pad 4- Try to "transform" (right click over cloned object in tree view) -> nothing happens (well, report view says: "This object type is not editable") 5- Save the file, close FreeCAD. Open the file. 6- Right click over cloned object in tree view: "transform" -> now you can move the clone freely. | ||||
| Additional Information | Forum topic: http://forum.freecadweb.org/viewtopic.php?f=3&t=11841 Bug reproduced by the user quick61, his FreeCAD info: OS: Kubuntu 14.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4671 (Git) Branch: releases/FreeCAD-0-15 Hash: 244b3aef360841646cbfe80a1b225c8b39c8380c Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
| 2015-07-25 09:46 | JMG_BT | New Issue | |
| 2015-07-25 17:28 | yorik | Note Added: 0006258 | |
| 2015-07-25 17:28 | yorik | Assigned To | => yorik |
| 2015-07-25 17:28 | yorik | Status | new => assigned |
| 2015-12-11 13:08 | yorik | Changeset attached | => FreeCAD Master master 3dcc557e |
| 2015-12-11 13:08 | yorik | Status | assigned => closed |
| 2015-12-11 13:08 | yorik | Resolution | open => fixed |
