0000220FreeCADBugpublic2010-12-20 10:39
Reporterunauthenticated Assigned To
Status closedResolutionfixed
Product Version0.10
Summary0000220: The "regular solid" option for mesh generation imposes strict limits on parameter values
DescriptionWhen I try creating a cylindrical mesh using the "regular solid" option in the "meshes" menu, the edge length is limited to ten units.
A workaround to this problem is to create a conical "regular solid" mesh with a constant radius. The limitation is not there in that case.
slukic
2010-12-19 17:29
reporter   ~0000461
Also the mesh dimensions are limited to 1000 units.
2010-12-20 10:39
administrator   ~0000462
Fixed in rev. 3822
2010-12-19 17:12 unauthenticated New Issue
2010-12-19 17:29 slukic Note Added: 0000461
2010-12-20 10:39 wmayer Note Added: 0000462
2010-12-20 10:39 wmayer Status new => closed
2010-12-20 10:39 wmayer Resolution open => fixed
