| 0002200 | FreeCAD | Bug | public | 2015-07-25 12:54 | 2016-02-28 17:57 |
| Reporter | Blindleistung | Assigned To | wmayer | ||
| Platform | Windows | OS | Windows7 | OS Version | x64 |
| Summary | 0002200: Application crash when modifying fillet | ||||
| Description | Application crashes when changed affected edges on a cut of two cylinders. When doing a boolean-subtract to cut a thin cylinder through a bigger cylinder sideways, the round end of the cut becomes a set of 4 curved edges. Making a fillet for this set of four works, removing some crashes the Application. | ||||
| Steps To Reproduce | Steps 1-5 already done in file attached. But also reproduces every time when clicking a new model. 1. Make Cylinder, 10mm tall, 2mm radius, move to 0/0/-5mm. 2. Make Cylinder, 10mm tall, 1mm radius, move to -5mm/0/0, rotate 90deg around (0/1/0) ( they should intersect at their centers now ) 3. Create boolean-diff, subtracting the thin from the thick. 4. Select the four parts of edge on one end of the cut-through hole. 5. Add a fillet with 0.2mm radius. (or load the file attached and start @ 6) 6. Double-click 'Fillet' in Hierarchy, deselect last of 4 edges in fillet. 7. Click OK. Nothing changes in object in view. 8. Double-click 'Fillet' in Hierarchy, deselect last of 3 edges in fillet. 9. Application crashes immediately when clicking on the check. | ||||
It doesn't crash for me with current master code... But the fillet indeed cannot be executed for several combinations of edges... I suppose this is a limitation of OpenCasCade, not sure we can do much about it... |
I can confirm this crash. However, it happens when de-selecting the last of the four edges. It's caused by a recursive call of SelectionSingleton::rmvSelection() which corrupts the internal iterator variable. |
| 2015-07-25 12:54 | Blindleistung | New Issue | |
| 2015-07-25 12:54 | Blindleistung | File Added: reproCrash.FCStd | |
| 2015-08-05 02:29 | yorik | Note Added: 0006273 | |
| 2016-02-28 16:21 | wmayer | Note Added: 0006853 | |
| 2016-02-28 16:21 | wmayer | Assigned To | => wmayer |
| 2016-02-28 16:21 | wmayer | Status | new => confirmed |
| 2016-02-28 17:57 | wmayer | Changeset attached | => FreeCAD Master master 4e29db90 |
| 2016-02-28 17:57 | wmayer | Status | confirmed => closed |
| 2016-02-28 17:57 | wmayer | Resolution | open => fixed |
| 2016-02-28 17:57 | wmayer | Fixed in Version | => 0.16 |
