| 0002213 | FreeCAD | Bug | public | 2015-08-16 11:37 | 2016-03-01 04:14 |
| Reporter | schultzc | Assigned To | jmaustpc | ||
| OS | Windows | OS Version | 10 | ||
| Summary | 0002213: Points in sketches not selectable under Windows 10 | ||||
| Description | After switching to Windows 10 I cannot select any points any more, when editing sketches. It will always select the lines of the points (single points can still be selected). By using box selection points cannot be selected, but when I try to apply any constraints it tells me, I shall only select single points. So obviously box selection also selects other objects I am not aware of. | ||||
| Steps To Reproduce | Create a rectangle under Windows 10. Try to add symmetry by selecting two points and the center point. | ||||
Hi thank you for taking the time to create a ticket, however please always discuss something in the help forum first, no matter how sure you are that you have found a bug, so that we can keep the number of tickets down and their quality up. Then always post a link to the topic in the bug ticket. I suspect that your issue may be fixed by updating your GPU driver. Also FreeCAD 0.15 is almost obsolete now, does this issue still happen in FreeCAD 0.16? This ticket is now quite old, are you still having this issue any more? I am trying to clean up the bug tickets so I will close this ticket for now, if you are still having issues please discuss it first in the Help forums first and if needed we can reopen tickets. |
Suspected GPU driver issue, best discussed on the forums first, |
| 2015-08-16 11:37 | schultzc | New Issue | |
| 2016-03-01 04:13 | jmaustpc | Note Added: 0006866 | |
| 2016-03-01 04:14 | jmaustpc | Note Added: 0006867 | |
| 2016-03-01 04:14 | jmaustpc | Status | new => closed |
| 2016-03-01 04:14 | jmaustpc | Assigned To | => jmaustpc |
| 2016-03-01 04:14 | jmaustpc | Resolution | open => no change required |
