| 0002219 | FreeCAD | Bug | public | 2015-08-18 01:50 | 2015-12-15 13:17 |
| Reporter | bhouston | Assigned To | yorik | ||
| OS | Windows 10 | ||||
| Summary | 0002219: Exporting to DAE from STEP import crashes on these files. | ||||
| Description | It is a simple crash during export. | ||||
| Steps To Reproduce | Import any of the following STEP files (though most STEP files work, I'm finding roughly 20% do not because of this crash): https://www.dropbox.com/s/0k3jt9ee8p849pu/A320.STEP?dl=0 https://www.dropbox.com/s/wonwr3fwf6alram/Veyron.STEP?dl=0 Then try to export as a Collada/DAE. It will crash. | ||||
| Additional Information | Full stack trace: Traceback (most recent call last): File "<string>", line 4, in <module> File "C:\Program Files\FreeCAD 0.15\Mod\Arch\importDAE.py", line 139, in export n = f.normalAt(0,0) <class 'Part.OCCError'>: normal not defined Stack Trace: Traceback (most recent call last): File "<string>", line 4, in <module> File "C:\Program Files\FreeCAD 0.15\Mod\Arch\importDAE.py", line 139, in export n = f.normalAt(0,0) Traceback (most recent call last): File "<string>", line 4, in <module> File "C:\Program Files\FreeCAD 0.15\Mod\Arch\importDAE.py", line 139, in export n = f.normalAt(0,0) <class 'Part.OCCError'>: normal not defined Stack Trace: Traceback (most recent call last): File "<string>", line 4, in <module> File "C:\Program Files\FreeCAD 0.15\Mod\Arch\importDAE.py", line 139, in export n = f.normalAt(0,0) | ||||
Hm never seen a face with normal not defined before... In any case should be an easy fix, but I'll have a look first as of why this happens |
Ok I didn't find the cause, but in any case used a more robust method now that should not produce that error anymore. However these two files are very big, and will need a lot of memory to export. It is advisable to convert them to meshes simplifying them a lot before exporting.. |
| 2015-08-18 01:50 | bhouston | New Issue | |
| 2015-08-18 16:47 | yorik | Assigned To | => yorik |
| 2015-08-18 16:47 | yorik | Status | new => assigned |
| 2015-08-18 16:52 | yorik | Note Added: 0006296 | |
| 2015-08-28 20:47 | yorik | Changeset attached | => FreeCAD Master master f70d5be2 |
| 2015-08-28 20:47 | yorik | Status | assigned => closed |
| 2015-08-28 20:47 | yorik | Resolution | open => fixed |
| 2015-08-28 20:49 | yorik | Note Added: 0006301 | |
| 2015-09-07 18:15 | yorik | Relationship added | has duplicate 0002241 |
| 2015-12-15 13:17 | yorik | Fixed in Version | => 0.16 |
