| 0002222 | FreeCAD | Bug | public | 2015-08-19 18:02 | 2015-12-15 13:17 |
| Reporter | hyOzd | Assigned To | wmayer | ||
| Platform | Linux | OS | Ubuntu 15.04 | ||
| Summary | 0002222: Number of normals in exported VRML is wrong | ||||
| Description | When I export a simple Box shape created with Part workbench to VRML, exported file has some problems. I've noticed the problem with view3dscene program. Shape is not shaded correctly by view3dscene and these warnings are displayed; VRML/X3D: Invalid number of items in a normal or texture array of shape "IndexedFaceSet": not enough items: 24, but at least 32 required. This problem happens with all solid primitives of Part workbench. But doesn't happen with some other shape types. For example fusion is exported fine. I've investigated the exported file myself and indeed there are 32 vertices but only 24 normals are defined. I'm using latest freecad build, 0.16 5351 git. | ||||
| Steps To Reproduce | 1. Create a new document 2. Switch to Part Workbench 3. Create a box shape 4. Select the box shape 5. Export to VRML using menu File->Export 6. Open the exported file using view3dscene viewer | ||||
| Additional Information | Removing Normals node from the VRML file hand seems to solve the problem. | ||||
I can confirm that the VRML file has 24 normals but this is actually correct. The cube has only sharp edges which means that the normals are for the four corners of the six faces (4*6=24). This means that each vertex has three associated normals to get the sharp edges. Now, the transition from Inventor nodes to VRML nodes may lose some information which may cause the rendering artefacts. However, it's also possible that 'view3dscene' just doesn't support this situation very well because Coin3d does the rendering correctly. |
After your comment, I've checked the file again. I think there are no missing normals but 'extra coordinate points'. If you look at the "DEF _+1 Coordinate{}" from line 38, it contains 32 coordinate points. But these points are not used for either IndexedLineSet or IndexedFaceSet. I've removed 8 points from the end of coordinate list. In this case view3dscene rendered the file correctly and gave no warnings. But on the other hand, these 'extra' points are actually used by "PointSet" at line 151. So they may not be unnecessary or extra. |
It looks like there are too many points but this is actually OK. A part shape has an SoBrepPointSet, an SoBrepLineSet and an SoBrepFaceSet. All of them share the same SoCoordinate3 node but they use the coordIndex attribute to reference the actual points they render. So, for the example of the box we have this situation: * there are 8 vertexes => 8 points * the edges append all their points to the list => 12 edges => 12*2 = 24 points * the faces share all of the points of the edges and have no extra points => 0 In total we have 8 + 12*2 = 32 points. And since we use index-based shape nodes this works all fine. So, I'm still not sure if the transition to VRML doesn't handle this special case or if 'view3dscene' doesn't support this. Anyway, a workaround is to tmp. set the normal binding to 'overall' so that the VRML file doesn't include the normals. |
| 2015-08-19 18:02 | hyOzd | New Issue | |
| 2015-08-19 18:02 | hyOzd | File Added: broken.wrl | |
| 2015-08-19 18:02 | hyOzd | File Added: broken_0.png | |
| 2015-09-13 23:06 | wmayer | Status | new => confirmed |
| 2015-09-14 11:15 | wmayer | Note Added: 0006416 | |
| 2015-09-14 11:34 | hyOzd | Note Added: 0006417 | |
| 2015-09-14 12:09 | wmayer | Note Added: 0006418 | |
| 2015-09-14 12:45 | wmayer | Changeset attached | => FreeCAD Master master c135ca40 |
| 2015-09-14 12:45 | wmayer | Assigned To | => wmayer |
| 2015-09-14 12:45 | wmayer | Status | confirmed => closed |
| 2015-09-14 12:45 | wmayer | Resolution | open => fixed |
| 2015-12-15 13:17 | yorik | Fixed in Version | => 0.16 |
