| 0002230 | FreeCAD | Bug | public | 2015-08-28 09:04 | 2015-12-15 13:17 |
| Reporter | Hannu | Assigned To | |||
| Platform | Linux | OS | Ubuntu | OS Version | 14.04.3 |
| Summary | 0002230: Error in `/usr/share/doc-base/freecad-development-documentation', line 15: all `Format' sections are invalid. | ||||
| Description | --- apt-get upgrade, the last lines --- ... Processing triggers for shared-mime-info (1.2-0ubuntu3) ... Processing triggers for doc-base (0.10.5) ... Processing 1 changed doc-base file... Error in `/usr/share/doc-base/freecad-development-documentation', line 15: all `Format' sections are invalid. Note: `install-docs --verbose --check file_name' may give more details about the above error. Setting up bash-completion (1:2.1-4ubuntu0.1) ... Setting up firefox (40.0.3+build1-0ubuntu0.14.04.1) ... Please restart all running instances of firefox, or you will experience problems. Setting up firefox-locale-en (40.0.3+build1-0ubuntu0.14.04.1) ... Setting up firefox-locale-sv (40.0.3+build1-0ubuntu0.14.04.1) ... Setting up qemu-user-static (2.0.0+dfsg-2ubuntu1.17) ... > Setting up freecad (1:0.16+bzr3961+201508272328~ubuntu14.04.1) ... > Setting up freecad-doc (1:0.16+bzr3961+201508272328~ubuntu14.04.1) ... Processing triggers for menu (2.1.46ubuntu1) ... --- done --- --- OS: Ubuntu 14.04.3 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.5371 (Git) Build type: None Branch: master Hash: daa024cc79aaf440fe43fe8b47c060012b2891de Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a | ||||
| Steps To Reproduce | This has appeared in at least the last two sessions of: $ sudo apt-get upgrade | ||||
| Additional Information | Note: I'm a novice on the content of freecad and documentation, beginner as user - that is all. | ||||
