| 0002231 | Arch | Bug | public | 2015-08-29 11:48 | 2015-09-01 14:09 |
| Reporter | Goofy03 | Assigned To | yorik | ||
| Platform | Linux | OS | Arch linux | OS Version | 4.1.6-1-ARCH |
| Summary | 0002231: Open an old 0.14 file take 30 min | ||||
| Description | I have modelized my house with 0.14. Now when i try to reopen it with 0.15 it take 30 min. FreeCAD seem to be crash but finally open the file after 20 or 30 min … I try to save it with new version but the problem stay the same. | ||||
Can you please attach your file? |
ok file added |
It opens instantly for me in 0.16... Can you paste here the info obtained from FreeCAD in menu help->About FreeCAD->copy to clipboard? (Load the Part workbench before doing that otherwise it doesn't show the OCC version) |
It try 0.16 too same problem i use the freecad-git aur package on arch … This is for the 0.15 freecad arch standard pacakage OS: "Arch Linux" Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4671 (Git) Branch: origin/releases/FreeCAD-0-15 Hash: 244b3aef360841646cbfe80a1b225c8b39c8380c Python version: 2.7.9 Qt version: 4.8.6 Coin version: 3.1.3 OCC version: 6.9.0 |
Hmm I'm still with OCC 6.8. It might be the cause of the problem... |
ok i downgrade the opencascade pkg and you're right it take a minute now … I see the model tree but nothing is displaying in … Get this kind of messages on all my models : Cannot create object 'Pad': (/usr/lib/freecad/Part.so: undefined symbol: _ZNK17GeomAdaptor_Curve11NbIntervalsE13GeomAbs_Shape) Lost link to 'Mur' while loading, maybe an object was not loaded correctly I suppose the official arch package is compile for OCC 6.9 i going to compile the 0.16 with git aur package … |
Ok it work with 0.16 git pkg + OCC 6.8 but can't save the windows/doors even after modifications to correct «disappeared bug» |
Ok. Then we have apparently a bug in OCC 6.9... In any case, your problem with windows not appearing is a bug in 0.14. To fix your file, enter this code in the python console and save it again: import Draft for o in FreeCAD.ActiveDocument.Objects: if Draft.getType(o) == "Window": o.removeProperty("Subvolume") o.touch() FreeCAD.ActiveDocument.recompute() |
Cool everything is ok now :) I hope I can work on modification for my building permit now and break all this concreate with a real jackhammer soon ;-) … Thanks for your help |
Ok I'll close this bug report for now, since there is nothing we can do about it. Please reopen if needed. |
| 2015-08-29 11:48 | Goofy03 | New Issue | |
| 2015-08-29 23:00 | yorik | Note Added: 0006304 | |
| 2015-08-29 23:05 | Goofy03 | File Added: Maison_final_01.fcstd | |
| 2015-08-29 23:06 | Goofy03 | Note Added: 0006305 | |
| 2015-08-30 15:40 | yorik | Note Added: 0006306 | |
| 2015-08-30 15:40 | yorik | Assigned To | => yorik |
| 2015-08-30 15:40 | yorik | Status | new => assigned |
| 2015-08-30 16:17 | Goofy03 | Note Added: 0006307 | |
| 2015-08-31 21:19 | yorik | Note Added: 0006310 | |
| 2015-08-31 21:42 | Goofy03 | Note Added: 0006311 | |
| 2015-08-31 21:42 | Goofy03 | Note Edited: 0006311 | |
| 2015-08-31 23:30 | Goofy03 | Note Added: 0006312 | |
| 2015-09-01 00:20 | yorik | Note Added: 0006313 | |
| 2015-09-01 00:40 | Goofy03 | Note Added: 0006315 | |
| 2015-09-01 14:09 | yorik | Note Added: 0006316 | |
| 2015-09-01 14:09 | yorik | Status | assigned => closed |
| 2015-09-01 14:09 | yorik | Resolution | open => not fixable |
| 2015-09-01 14:09 | yorik | Fixed in Version | => 0.16 |
