| 0002233 | Arch | Bug | public | 2015-08-30 19:32 | 2016-01-19 02:06 |
| Platform | Kubuntu vivid | ||||
| Summary | 0002233: Drawing view of Arch SectionView changes orientation when changing rendering mode | ||||
| Description | When an Arch SectionView is on a drawing sheet, its orientation on the sheet changes when the rendering mode is changed from wireframe to solid or vice-versa. | ||||
| Steps To Reproduce | 1. Open the architectorial example model from the start page. 2. Go to the drawing page, select one of the two section views on the drawing page via the tree view. 3. Change the property "Rendering Mode" from wireframe to solid or from solid to wireframe -> the orientation of the view of the section on the page changes. | ||||
| Additional Information | OS: Ubuntu 15.04 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.5371 (Git) Build type: None Branch: master Hash: daa024cc79aaf440fe43fe8b47c060012b2891de Python version: 2.7.9 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
Indeed... Must unify that. |
This is now fixed, as far as possible. Sometimes the wireframe view rotates, which is done by opencascade and is unpredictable. For "normal" cases where no rotation occurs (XY projection for ex.) this now works correctly |
| 2015-08-30 19:32 | mghansen256 | New Issue | |
| 2015-08-30 21:14 | yorik | Note Added: 0006308 | |
| 2015-08-30 21:14 | yorik | Assigned To | => yorik |
| 2015-08-30 21:14 | yorik | Status | new => assigned |
| 2015-12-23 13:33 | yorik | Changeset attached | => FreeCAD Master master 474c114e |
| 2015-12-23 13:33 | yorik | Status | assigned => closed |
| 2015-12-23 13:33 | yorik | Resolution | open => fixed |
| 2015-12-23 13:34 | yorik | Note Added: 0006629 | |
