0002239FreeCADBugpublic2015-12-15 13:17
Reporterdrone115b Assigned Totanderson69
PlatformLinuxOSUbuntuOS Version14.04 LTS
Product Version0.15
Fixed in Version0.16
Summary0002239: Fusion operation exception
DescriptionI have a complex solid and a simple cube. In some positions, the two can be combined with a fusion operation. In some positions, an exception is thrown.
In my private, not-shared, non-simplified project file, I'm hitting 2GB of RAM before the exception is thrown. In the included file, the exception seems to be thrown quickly. I have modelled a very similar part like this previously and did not have a problem before.
I believe I'm using 0.15.4671 32b compile for Ubuntu 14.04 LTS.
While "minor" in the face of the rest of the world, this is a deal-breaker for my project. I have spent all night trying work-arounds to no avail. Any help is appreciated. Thanks.
Steps To ReproduceIn the enclosed file, the fusion between the complex solid and the cube throws an exception for me. If the cube is returned to default position, the fusion works correctly.
drone115b
2015-09-03 02:46
reporter
test_006.fcstd (Attachment missing)
tanderson69
2015-09-03 14:09
developer
tanderson69
2015-09-03 14:18
developer   ~0006328
You have an invalid solid. Use check geometry from the part workbench. With invalid solids, modeling operations will be unpredictable. This is especially true for boolean operations. Incorrect usage of loft.
Depending on your freecad and solid modeling experience, it is best to start your problem solving on the forums and let the advanced users help determine if you have a bug. This eases the burden on the developers managing the bug tracker. Thanks.
tanderson69
2015-09-03 14:21
developer   ~0006329
incorrect usage.
2015-09-03 02:46 drone115b New Issue
2015-09-03 02:46 drone115b File Added: test_006.fcstd
2015-09-03 14:09 tanderson69 File Added: invalidSolid.png
2015-09-03 14:18 tanderson69 Note Added: 0006328
2015-09-03 14:21 tanderson69 Note Added: 0006329
2015-09-03 14:21 tanderson69 Status new => closed
2015-09-03 14:21 tanderson69 Assigned To => tanderson69
2015-09-03 14:21 tanderson69 Resolution open => no change required
2015-12-15 13:17 yorik Fixed in Version => 0.16
