| 0000224 | FreeCAD | Feature | public | 2010-12-23 16:52 | 2011-10-14 16:51 |
| Summary | 0000224: Turn the Draft workplane marker into something more powerful | ||||
| Description | When opening FreeCAD and drawing a line there is a nice big temporary origin/axis displayed (similar in my mind to Accudraw in MicroStation). Does this 'origin' do anything other than mark the start of the line at the moment? What I would really like to be able to do with it is to invoke it at a point, then move a certain distance away from it before starting to draw the line. For example, I want to draw the reveal of a window and I know that it is located 700mm from the corner of the building. I would like to snap to the corner of the building, place the origin there, move 700mm away, then draw the line for the reveal of the window. It would also be nice if it was sized relative to the window (independent of the zoom / scale of the drawing). When trying to draw a house it is too small to seen... It would also be nice to be able to rotate it so that temporarily I could draw at an angle not orthogonal to the view. Ideally this would be 'sticky' so that it would stay rotated until I specifically told it to go back to the default orientation. Which leads me on to my final wish... Could all tools be made 'sticky'? i.e. the line tool stays selected and ready to draw another line after I've drawn the previous one. Sorry for the mini wish-list, they are just things that I've been thinking of as I'm trying to use FreeCAD. NIck | ||||
| Additional Information | Discussion thread: http://sourceforge.net/apps/phpbb/free-cad/viewtopic.php?f=3&t=725 | ||||
Also set the workplane to a face when the first point is on a face |
done in r5022: - When drawing wires, it is now possible to draw some segments, then wipe the existing segments, restarting the wire at the last point - The axis marker size is now relative to the view, and depends on the Draft snap aperture parameter - Rotating the working plane is 100% handled by the working plane commands - Drawing commands have a "continue" checkbox that allow to automatically restart the command once it has finished |
| 2010-12-23 16:52 | yorik | New Issue | |
| 2010-12-23 16:52 | yorik | Status | new => assigned |
| 2010-12-23 16:52 | yorik | Assigned To | => yorik |
| 2011-02-13 18:30 | yorik | Relationship added | parent of 0000202 |
| 2011-03-16 21:42 | yorik | Note Added: 0000740 | |
| 2011-10-14 16:51 | yorik | Note Added: 0001153 | |
| 2011-10-14 16:51 | yorik | Status | assigned => closed |
| 2011-10-14 16:51 | yorik | Resolution | open => fixed |
| 2011-10-14 16:51 | yorik | Fixed in Version | => 0.12 |
