0002240FreeCADBugpublic2015-11-05 13:26
Reporterbordev Assigned Toyorik
PlatformLinux, amd64OSGentoo
Product Version0.14
Fixed in Version0.16
Summary0002240: Incorrect object dimensions
DescriptionDimension annotation shows different values than sketch
Steps To ReproduceI created square object by creating rectangle and setting length constraints on both sides to 99.4mm.
Later, after adding more details and finishing the piece I added the dimensions annotation to double check if everything is correct, and to my surprise it shows different values (see attached file).
Unfortunately it also shows these wrong values on exported .step files.
bordev
2015-09-03 12:36
reporter
yorik
2015-09-06 02:40
administrator   ~0006334
Can you please attach the file too? Thanks.
bordev
2015-09-07 10:32
reporter
freecad.fcstd (Attachment missing)
bordev
2015-09-07 10:34
reporter   ~0006337
I've attached the project file. When I've tried to reproduce the problem, I get different values when attaching the dimension annotation - sometimes it's ok: 99.400, sometimes it's some random(?) value between 99.3 and 99.4
yorik
2015-09-10 19:29
administrator   ~0006391
This is not a bug, actually.
The model is okay and has the correct dimensions (all edges have 99.4mm). What is wrong is that the dimension that shows 99.323 was not well created, its measurement points are not exactly on the endpoints.
When creating a measurement, always check that you are exactly on a vertex before clicking. The status bar of FreeCAD will indicate if you are on a vertex or on an edge. Only click when you are on a vertex, and you will have the correct measurement.
You can increase the Points Size property in your object if it is difficult to achieve...
I'm going to close this issue since there is nothing necessary for us to do here, don't hesitate to reopen if needed.
bordev
2015-09-14 10:36
reporter   ~0006415
(Sorry to reopen this, but I don't see an option to comment without reopening)
Yes, you're right that it's incorrectly created dimension, but still, in my version I'm able to create incorrect dimensions, even when display highlights a dot and the status bar indicates that I'm on a vertex. (I retested it on a simple 2d design imported from .dxf)
To retest try to put dimension where it still says it's on vertex, but the mouse pointer is not exactly above the highlighted dot.
The exact Freecad package version in Gentoo that I'm using is: 0.14.3702-r1
yorik
2015-09-14 14:25
administrator   ~0006421
For me it still works OK... It might be worth testing a more recent version, 0.14 is a bit old, many things have been fixed since then.
bordev
2015-09-17 08:56
reporter
test.dxf (Attachment missing)
bordev
2015-09-17 08:56
reporter
test.fcstd (Attachment missing)
bordev
2015-09-17 09:00
reporter   ~0006428
I've uploaded test files on which I'm able to create incorrect dimensions - although it doesn't fail every time, I manage to create wrong dimension every 3-4 times on this file.
As for testing on newer version, currently I can't do that. I wanted to install 0.15, but on Gentoo it doesn't compile, as far as I remember there where some problems with Opencascade, probably incorrect version, I'm not sure
yorik
2015-11-05 13:26
administrator   ~0006530
I'm closing this since apparently it doesn't require any change in FreeCAD (works with up-to-date version). Please reopen if needed.
2015-09-03 12:36 bordev New Issue
2015-09-03 12:36 bordev File Added: freecad.jpg
2015-09-06 02:40 yorik Note Added: 0006334
2015-09-06 02:40 yorik Status new => feedback
2015-09-07 10:32 bordev File Added: freecad.fcstd
2015-09-07 10:34 bordev Note Added: 0006337
2015-09-07 10:34 bordev Status feedback => new
2015-09-10 19:29 yorik Note Added: 0006391
2015-09-10 19:29 yorik Status new => closed
2015-09-10 19:29 yorik Assigned To => yorik
2015-09-10 19:29 yorik Resolution open => no change required
2015-09-10 19:29 yorik Fixed in Version => 0.16
2015-09-14 10:36 bordev Note Added: 0006415
2015-09-14 10:36 bordev Status closed => feedback
2015-09-14 10:36 bordev Resolution no change required => reopened
2015-09-14 14:25 yorik Note Added: 0006421
2015-09-17 08:56 bordev File Added: test.dxf
2015-09-17 08:56 bordev File Added: test.fcstd
2015-09-17 09:00 bordev Note Added: 0006428
2015-09-17 09:00 bordev Status feedback => assigned
2015-11-05 13:26 yorik Note Added: 0006530
2015-11-05 13:26 yorik Status assigned => closed
2015-11-05 13:26 yorik Resolution reopened => no change required
