| 0000225 | FreeCAD | Bug | public | 2010-12-24 13:07 | 2011-04-26 13:32 |
| Summary | 0000225: bugs in Draft Scale | ||||
| Description | #one can't edit elements after scaling When you draw something in the draw module and scale it (second time (see first point)) you can't edit the drawing after the scaling. #closed line elements becomes filled elements after scaling the first time. If you draw a circle, rectangle or a polygon (rectangle...) and try to scale them they will become filled elements (faces). | ||||
| 2010-12-24 13:07 | yorik | New Issue | |
| 2010-12-24 13:07 | yorik | Status | new => assigned |
| 2010-12-24 13:07 | yorik | Assigned To | => yorik |
| 2011-04-26 13:32 | yorik | Note Added: 0000804 | |
| 2011-04-26 13:32 | yorik | Status | assigned => closed |
| 2011-04-26 13:32 | yorik | Resolution | open => fixed |
| 2011-04-26 13:32 | yorik | Fixed in Version | => 0.12 |
