| 0002257 | PartDesign | Feature | public | 2015-09-10 19:18 | 2016-01-31 19:14 |
| Reporter | severoraz | Assigned To | |||
| Priority | normal | Severity | tweak | Reproducibility | N/A |
| Summary | 0002257: Implement definition of dimension constraint value with spreadsheet cell value | ||||
| Description | Implementing this feature would allow quick remodeling of parts based on parameters that may be shared by multiple parts in a machine. For example, if you design a bike hub and you decide you want to change the axle diameter, you would need to edit every part of the hub to adapt it to the new axle diameter, whereas if you could define the axle diameter in a spreadsheet and have parts take that value for dimension constraints, simply modifying the spreadsheet would render your job done. | ||||
This functionality is soon to be merged into master; see http://forum.freecadweb.org/viewtopic.php?f=10&t=8802 |
This is now in master, so this ticket can be closed. |
| 2015-09-10 19:18 | severoraz | New Issue | |
| 2015-09-12 07:49 | eivindkvedalen | Note Added: 0006396 | |
| 2015-10-06 21:03 | eivindkvedalen | Note Added: 0006484 | |
| 2016-01-31 19:14 | yorik | Status | new => closed |
| 2016-01-31 19:14 | yorik | Resolution | open => fixed |
| 2016-01-31 19:14 | yorik | Fixed in Version | => 0.16 |
