| 0002259 | FreeCAD | Bug | public | 2015-09-11 22:50 | 2015-12-15 13:17 |
| Reporter | Aussie58 | Assigned To | wmayer | ||
| Platform | Macintosh | OS | osx yosemite | OS Version | 10.10.5 |
| Summary | 0002259: rendering issue on axonometric surface | ||||
| Description | was completing the turorial @ https://www.youtube.com/watch?v=_HEvhclR4-o&index=7&list=WL I drew the cube and cylinder - no problems when viewing the surfaces in axonometric view there is an overlap between the cylinder and cube surfaces. attached screenshots show the issue with a red arrow | ||||
There is not enough information in what you submitted to know what the problem is... And the attached pdf only shows a warning dialog... Please give us a step-by-step procedure explaining how we can reproduce your problem, and if possible a screenshot showing the problem happening, thanks! |
Apologies for the misinformation. I was at the beginning of the youtube lesson 1 after following the step by step procedure. attached now is the 3 page screenshot of the issue. image 1: my system image2 and 3 : the 'arrowed' issue cheers |
This is a know phenomenon in 3d rendering called z-fighting and actually not a bug. See: https://en.wikipedia.org/wiki/Z-fighting If a shaded and a wireframe display of the _same_ model is done this can be fixed by the use of a polygon offset. But with two independent objects like in this case it's nearly impossible to do something against it. |
Understood - thank you - sorry for the hassle. I am returning to using CAD after teaching it to high school kids back in the 80's and 90's - things have changed just a little. Cheers. Case closed! :-) |
| 2015-09-11 22:50 | Aussie58 | New Issue | |
| 2015-09-11 22:50 | Aussie58 | File Added: 3 images.pdf | |
| 2015-09-13 14:07 | yorik | Project | Draft => FreeCAD |
| 2015-09-13 14:09 | yorik | Note Added: 0006406 | |
| 2015-09-13 14:09 | yorik | Status | new => feedback |
| 2015-09-13 21:14 | Aussie58 | File Added: system.pdf | |
| 2015-09-13 21:14 | Aussie58 | Note Added: 0006413 | |
| 2015-09-13 21:14 | Aussie58 | Status | feedback => new |
| 2015-09-14 13:00 | wmayer | Note Added: 0006419 | |
| 2015-09-15 09:31 | wmayer | Status | new => feedback |
| 2015-09-15 09:56 | Aussie58 | Note Added: 0006425 | |
| 2015-09-15 09:56 | Aussie58 | Status | feedback => new |
| 2015-09-15 10:05 | wmayer | Status | new => closed |
| 2015-09-15 10:05 | wmayer | Assigned To | => wmayer |
| 2015-09-15 10:05 | wmayer | Resolution | open => not fixable |
| 2015-12-15 13:17 | yorik | Fixed in Version | => 0.16 |
