0002263PartDesignFeaturepublic2015-12-15 13:15
Reporterseveroraz Assigned Toabdullah
Product Version0.15
Fixed in Version0.16
Summary0002263: Enable vertical and horizontal constraint for points
DescriptionIt would come in handy to set vertical or horizontal constraints for pairs of points.
A vertical constraint for a pair of points would make them have the same horizontal position (hence they would be connected by a vertical line)
A horizontal constraint would make them have the same vertical position.
yorik
2015-09-14 16:21
administrator   ~0006422
It exists already... If you have a line between the points, you can set a vertical/horizontal constraint. If you want to do that on two points without a line connecting them, you can use a vertical or horizontal distance constraint set to zero...
severoraz
2015-09-27 17:05
reporter   ~0006469
Well that's true, it is possible right now, but why not subscract a step from such a common operation?
abdullah
2015-10-04 09:24
manager   ~0006475
What about using a construction line and assign the vertical/horizontal constraint to it?
What you request, while possible, does not seem to follow the logic behind the sketcher. I explain myself:
1. If you want to limit one of the degrees of freedom of one point, then what Yorik says fully applies. This is a logic common operation.
2. If you want to limit one of the degrees of freedom of two points to a same value within the same sketch, then you are implicitly reducing two degrees of freedom (one per point) to a same value. So you want in addition to a normal point contraining, that the value is the same. This is an overcomplicated definition of a line. Most CAD users will just use a construction line here.
3. If you want to limit one of the degrees of freedom of two points of a same or different sketch to the same value, you can also use Eric's expressions (in the very recent PPA builds).
abdullah
2015-10-09 11:51
manager   ~0006489
As in my last reply. This functionality exist either by fixing a point dimensions, using a construction line or using expressions. Each solution applies better to different problems. The one described by the reported seem to be the use of a construction line.
2015-09-14 06:22 severoraz New Issue
2015-09-14 16:21 yorik Note Added: 0006422
2015-09-27 17:05 severoraz Note Added: 0006469
2015-10-04 09:24 abdullah Note Added: 0006475
2015-10-04 09:25 abdullah Assigned To => abdullah
2015-10-04 09:25 abdullah Status new => assigned
2015-10-09 11:51 abdullah Note Added: 0006489
2015-10-09 11:51 abdullah Status assigned => closed
2015-10-09 11:52 abdullah Resolution open => no change required
2015-12-15 13:15 yorik Fixed in Version => 0.16
