| 0002276 | FreeCAD | Feature | public | 2015-09-25 09:38 | 2016-01-19 02:06 |
| Reporter | hamish2014 | Assigned To | yorik | ||
| Platform | Linux x86_64 | OS | Ubuntu | OS Version | 14.04 LTS |
| Summary | 0002276: Drawing::PythonFeatureView | ||||
| Description | Hi, Would it be possible to either: a) add a Drawing::PythonFeatureView, which would be an extension of the Drawing::FeatureView base class, with support for adding properties and using proxies, or b) modify FreeCAD_sf_master/src/Mod/Drawing/App/FeaturePage.cpp: App::DocumentObjectExecReturn: to load contents from ViewResult property from objects in the pages group (relax the isDerivedFrom(Drawing::FeatureView::getClassTypeId() restriction) ? Either of these changes would greatly facilitate the development parametric functionality in the drawing dimensioning workbench. Thanks! | ||||
There is one already, called Drawing::FeatureViewPython |
b) is a good idea, I've been meaning to do that some time ago and forgot. |
Wow, i can't believe i never new about the Drawing::FeatureViewPython. Feeling sheepish now:) Forget about b) the Drawing::FeatureViewPython object looks like it can do everything i need it to for my purposes. Please close the issue. |
I'll implement b) anyway when I have a minute... It would be useful to have anyway. |
Hi, Played around with the Drawing::FeatureViewPython a little. I am encountering difficulty with the default view provider for Drawing::FeatureViewPython objects. Specifically, 1.) t.ViewObject.addProperty: AttributeError: 'Gui.ViewProviderDocumentObject' object has no attribute 'addProperty' 2.) t.ViewObject.Proxy: AttributeError: 'Gui.ViewProviderDocumentObject' object has no attribute 'Proxy' Any ideas? Perhaps, persueing option b) would be better: A user could then add a App::FeaturePython under the page group with a ViewResult property whose contents will be loaded into the drawing page. That way the ViewProviderPythonFeature functionality which does not suffer from 1) and 2) can be leveraged... |
Another thought regarding b): how about modifying FreeCAD_sf_master/src/Mod/Drawing/App/FeaturePage.cpp: App::DocumentObjectExecReturn: to load contents from both * the ViewResult property from objects DerivedFrom(Drawing::FeatureView::getClassTypeId()) and * objects which have a DrawingPageViewResult property. Where a verbose property name like `DrawingPageViewResult` would almost entirely eliminate the chances of a user accidentally using a property with name for another purpose... |
Indeed as far as I know the view provider of the Drawing::FeatureViewPython doesn't have a python version, it uses the defautl C++ one. Since the drawingview object doesn generate anything in the 3D view, I suppose nobody needed it... But indeed it could be nice so someone could change the icon and claim children from python code... |
FreeCAD: master 3bbddc86 2015-12-23 20:03:46 Details Diff |
Drawing: Added python feature to ViewProviderDrawingView - fixes 0002276 |
Affected Issues 0002276 |
| mod - src/Mod/Drawing/App/FeatureView.cpp | Diff File | ||
| mod - src/Mod/Drawing/Gui/AppDrawingGui.cpp | Diff File | ||
| mod - src/Mod/Drawing/Gui/ViewProviderView.cpp | Diff File | ||
| mod - src/Mod/Drawing/Gui/ViewProviderView.h | Diff File | ||
| 2015-09-25 09:38 | hamish2014 | New Issue | |
| 2015-09-25 14:22 | yorik | Note Added: 0006447 | |
| 2015-09-25 14:23 | yorik | Note Added: 0006448 | |
| 2015-09-25 14:23 | yorik | Assigned To | => yorik |
| 2015-09-25 14:23 | yorik | Status | new => assigned |
| 2015-09-25 14:54 | hamish2014 | Note Added: 0006449 | |
| 2015-09-25 14:56 | yorik | Note Added: 0006450 | |
| 2015-09-26 05:33 | hamish2014 | Note Added: 0006459 | |
| 2015-09-26 05:52 | hamish2014 | Note Added: 0006460 | |
| 2015-09-26 15:06 | yorik | Note Added: 0006464 | |
| 2015-12-23 19:04 | yorik | Changeset attached | => FreeCAD Master master 3bbddc86 |
| 2015-12-23 19:04 | yorik | Status | assigned => closed |
| 2015-12-23 19:04 | yorik | Resolution | open => fixed |
