| 0002277 | Sketcher | Bug | public | 2015-09-25 15:02 | 2015-09-28 10:43 |
| Reporter | triplus | Assigned To | abdullah | ||
| Summary | 0002277: Deleting sketcher geometry crashes FreeCAD | ||||
| Description | Deleting sketcher geometry crashes FreeCAD | ||||
| Steps To Reproduce | 1. Open the file Plate1.fcstd 2. edit sketch 3. select all elements 4. press Delete key http://forum.freecadweb.org/viewtopic.php?f=3&t=12588#p100939 | ||||
| Additional Information | http://forum.freecadweb.org/viewtopic.php?f=10&t=12591 | ||||
FreeCAD: master 56c29e27 2015-09-26 06:46:39 Committer: wmayer Details Diff |
Sketcher: Bug fix: Building Vertex Index on Restore =================================================== The bug was introduced by myself here: https://github.com/FreeCAD/FreeCAD/commit/47c0859c1b702b6c7d1dcf5922317c4f325f5d2e [code] void SketchObject::onDocumentRestored() { try { - rebuildExternalGeometry(); + if(Support.getValue()) { + validateExternalLinks(); + rebuildExternalGeometry(); + } Constraints.acceptGeometry(getCompleteGeometry()); } [/code] The issue is that "rebuildExternalGeometry" calls "rebuildVertexIndex". So for any sketch not having external geometry, if you open it, select everything and hit del, you will have a crash because I effectively removed the creation of the index in this dossier. You won't have one if you do anything rebuilding the index before hitting del, like creating geometry, though. |
Affected Issues 0002277 |
| 2015-09-25 15:02 | triplus | New Issue | |
| 2015-09-26 02:44 | abdullah | Assigned To | => abdullah |
| 2015-09-26 02:44 | abdullah | Status | new => assigned |
| 2015-09-28 10:43 | wmayer | Changeset attached | => FreeCAD Master master 56c29e27 |
| 2015-09-28 10:43 | wmayer | Status | assigned => closed |
| 2015-09-28 10:43 | wmayer | Resolution | open => fixed |
| 2015-09-28 10:43 | wmayer | Fixed in Version | => 0.16 |
