| 0002287 | FreeCAD | Bug | public | 2015-10-03 12:00 | 2015-12-15 13:15 |
| Reporter | Zoidberg | Assigned To | wmayer | ||
| Platform | x86 | OS | Windows | OS Version | 2000 |
| Summary | 0002287: Entry Point Not Found IsWow64Process | ||||
| Description | The program is installed correctly. When you run it appears - Entry Point Not Found. The procedure entry point IsWow64Process could not be located in the dynamic link library KERNEL32.dll | ||||
This bug has versions 0.13, 0.14, 0.15. Version 0.12 runs normally. |
This is the culprit: https://github.com/FreeCAD/FreeCAD/blob/master/src/Gui/3Dconnexion/GuiApplicationNativeEventAwareWin32.cpp#L404 because it directly calls IsWow64Process but Windows 2000's kernel32.dll lacks of this function. |
A list of missing functions on Windows 2000: kernel32.dll: SetDllDirectory CheckRemoteDebuggerPresent (needed by QtGui4.dll) user32.dll: DefRawInputProc GetRawInputBuffer GetRawInputData GetRawInputDeviceInfoA GetRawInputDeviceList RegisterRawInputDevices |
Script to check which dlls of FreeCAD and 3rd party libraries can be loaded: |
Since CheckRemoteDebuggerPresent is needed by QtGui there is no way to support Win2000. |
| 2015-10-03 12:00 | Zoidberg | New Issue | |
| 2015-10-03 12:04 | Zoidberg | Note Added: 0006474 | |
| 2015-10-06 19:47 | wmayer | Note Added: 0006483 | |
| 2015-10-06 19:48 | wmayer | Assigned To | => wmayer |
| 2015-10-06 19:48 | wmayer | Status | new => acknowledged |
| 2015-10-07 08:25 | wmayer | Changeset attached | => FreeCAD Master master 4909d628 |
| 2015-10-07 08:25 | wmayer | Status | acknowledged => closed |
| 2015-10-07 08:25 | wmayer | Resolution | open => fixed |
| 2015-10-08 16:53 | wmayer | Note Added: 0006488 | |
| 2015-10-08 16:53 | wmayer | Status | closed => feedback |
| 2015-10-08 16:53 | wmayer | Resolution | fixed => reopened |
| 2015-10-09 09:21 | wmayer | Note Edited: 0006488 | |
| 2015-10-09 12:14 | wmayer | Note Edited: 0006488 | |
| 2015-10-09 12:16 | wmayer | Note Added: 0006490 | |
| 2015-11-30 20:09 | wmayer | Note Added: 0006568 | |
| 2015-11-30 20:09 | wmayer | Status | feedback => closed |
| 2015-11-30 20:09 | wmayer | Resolution | reopened => not fixable |
