| 0002297 | Drawing | Bug | public | 2015-10-14 14:15 | 2015-12-15 13:15 |
| Reporter | mghansen256 | Assigned To | wmayer | ||
| Platform | Windows 7 | ||||
| Summary | 0002297: "Export to PDF..." from drawing view does not show an error if existing file can not be overwritten | ||||
| Description | When I export to a PDF file which is already open in a PDF viewer which locked the file for write access, FreeCAD does not update the file and does not show an error message. | ||||
| Steps To Reproduce | 1. Create or open a drawing page. 2. Use "File"->"Export to PDF..." and export to a PDF file 3. Open the PDF file in a PDF viewer that locks the file, like Adobe Acrobat or Foxit Reader, leave the PDF viewer open 4. Change something in the drawing. 5. Use "File"->"Export to PDF..." and export to the same PDF file, confirm the warning that the file will be overwritten. 6. Re-open the file in another viewer: The file was not updated, and FreeCAD did not warn about this. | ||||
| Additional Information | OS: Windows 7 Word size of OS: 64-bit Word size of FreeCAD: 32-bit Version: 0.16.5694 (Git) Build type: Release Branch: master Hash: c133457da59c20a233c4eaec428531896acdc071 Python version: 2.7.8 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
| 2015-10-14 14:15 | mghansen256 | New Issue | |
| 2015-10-16 22:31 | wmayer | Changeset attached | => FreeCAD Master master efd3a494 |
| 2015-10-16 22:31 | wmayer | Assigned To | => wmayer |
| 2015-10-16 22:31 | wmayer | Status | new => closed |
| 2015-10-16 22:31 | wmayer | Resolution | open => fixed |
