| 0002301 | FreeCAD | Bug | public | 2015-10-15 14:28 | 2015-11-28 13:03 |
| Reporter | jmaustpc | Assigned To | eivindkvedalen | ||
| Platform | 64bit | OS | Kubuntu | OS Version | 14.04 |
| Target Version | 0.16 | Fixed in Version | 0.16 | ||
| Summary | 0002301: Spreadsheet Tab button behaviour inconsistent | ||||
| Description | If you enter a value in a spreadsheet cell then press Tab key board button the value is accepted, then selection moves to the next cell down, in other situations Tab moves the cell selection to the next cell to the right or backwards tab, the selection moves left. | ||||
| Steps To Reproduce | If you enter a value in a spreadsheet cell then press Tab key board button the value is accepted, then selection moves to the next cell down, has the same effect as enter key however press tab again and selection moves to the next cell to the right. Also, as you would expect, if you just select a cell (default, it goes blue) then use tab or backward tab, the selection moves right and left. | ||||
FreeCAD: master b7480210 2015-11-08 11:15:20 Eivind Kvedalen Committer: wmayer Details Diff |
Spreadsheet: Issue 0002301: Handle enter/return and tab keys the same as e.g OpenOffice and Excel. |
Affected Issues 0002301 |
| mod - src/Mod/Spreadsheet/Gui/CMakeLists.txt | Diff File | ||
| add - src/Mod/Spreadsheet/Gui/LineEdit.cpp | Diff File | ||
| add - src/Mod/Spreadsheet/Gui/LineEdit.h | Diff File | ||
| mod - src/Mod/Spreadsheet/Gui/Sheet.ui | Diff File | ||
| mod - src/Mod/Spreadsheet/Gui/SheetModel.cpp | Diff File | ||
| mod - src/Mod/Spreadsheet/Gui/SheetTableView.cpp | Diff File | ||
| mod - src/Mod/Spreadsheet/Gui/SheetTableView.h | Diff File | ||
| mod - src/Mod/Spreadsheet/Gui/SpreadsheetDelegate.cpp | Diff File | ||
| mod - src/Mod/Spreadsheet/Gui/SpreadsheetView.cpp | Diff File | ||
| 2015-10-15 14:28 | jmaustpc | New Issue | |
| 2015-10-15 15:31 | jmaustpc | Assigned To | => eivindkvedalen |
| 2015-10-15 15:31 | jmaustpc | Status | new => assigned |
| 2015-11-28 12:05 | wmayer | Changeset attached | => FreeCAD Master master b7480210 |
| 2015-11-28 13:03 | wmayer | Status | assigned => closed |
| 2015-11-28 13:03 | wmayer | Resolution | open => fixed |
| 2015-11-28 13:03 | wmayer | Fixed in Version | => 0.16 |
