| 0002302 | PartDesign | Bug | public | 2015-10-16 17:40 | 2015-11-09 21:37 |
| Reporter | bcolsen | Assigned To | eivindkvedalen | ||
| Platform | Linux | OS | Ubuntu | OS Version | 14.04.3 |
| Summary | 0002302: Part design Fillets and Chamfers fail when using units in a fuction for the radius | ||||
| Description | Part design Fillets and Chamfers fail when defining a function for the radius like "20mm/10" or "1in/10". Works with 20/10 I'm using Ubuntu daily updated today. PS: I love the new function interface. Great work every one. | ||||
| Steps To Reproduce | 1. start new doc 2. make a cube in part workbench 3. select an edge 4. make a fillet or chamfer in part design workbench 5. click the function button in the radius option 6. enter 20mm/10 7. exception in Feature "Fillet" thrown: std::bad_cast | ||||
| Additional Information | Terminal output: --accepting rule at line 251 ("20") --accepting rule at line 164 ("mm") --accepting rule at line 149 ("/") --(end of buffer or a NUL) --accepting rule at line 251 ("10") --(end of buffer or a NUL) --EOF (start condition 0) exception in Feature "Fillet" thrown: std::bad_cast Version info: OS: Ubuntu 14.04.3 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.5747 (Git) Build type: None Branch: master Hash: 2e6c94fc8e2641e26611632d95e6a28a1618aa89 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
See https://github.com/eivindkv/free-cad-code/tree/PartDesign_fix_2302 for a fix. That branch also fixes a similar problem for chamfers. wmayer: This required changing the type of Radius and Size in the Fillet and Chamfer classes. I have copied your backwards-compatibility implementation from Pad to do the same in these cases. |
FreeCAD: master acd0f6a7 2015-10-25 21:48:39 Eivind Kvedalen Committer: wmayer Details Diff |
PartDesign: Fixed issue 0002302 with unit handling when using an expression for the fillet radius. |
Affected Issues 0002302 |
| mod - src/Mod/PartDesign/App/FeatureFillet.cpp | Diff File | ||
| mod - src/Mod/PartDesign/App/FeatureFillet.h | Diff File | ||
FreeCAD: master be5e7960 2015-10-25 21:56:53 Eivind Kvedalen Committer: wmayer Details Diff |
PartDesign: Fixed similar issue compared to 0002302 with unit handling when using an expression for the chamfer size. |
| mod - src/Mod/PartDesign/App/FeatureChamfer.cpp | Diff File | ||
| mod - src/Mod/PartDesign/App/FeatureChamfer.h | Diff File | ||
| 2015-10-16 17:40 | bcolsen | New Issue | |
| 2015-10-25 20:23 | eivindkvedalen | Assigned To | => eivindkvedalen |
| 2015-10-25 20:23 | eivindkvedalen | Status | new => assigned |
| 2015-10-25 21:29 | eivindkvedalen | Note Added: 0006502 | |
| 2015-11-09 21:04 | wmayer | Changeset attached | => FreeCAD Master master acd0f6a7 |
| 2015-11-09 21:37 | wmayer | Changeset attached | => FreeCAD Master master be5e7960 |
| 2015-11-09 21:37 | wmayer | Status | assigned => closed |
| 2015-11-09 21:37 | wmayer | Resolution | open => fixed |
| 2015-11-09 21:37 | wmayer | Fixed in Version | => 0.16 |
