| 0002315 | FreeCAD | Bug | public | 2015-10-29 15:14 | 2015-12-09 12:56 |
| Reporter | jmaustpc | Assigned To | abdullah | ||
| Platform | 64 bit | OS | Kubuntu | OS Version | 14.04 |
| Target Version | 0.16 | Fixed in Version | 0.16 | ||
| Summary | 0002315: Mirror Sketch - error pops up "can't find property" | ||||
| Description | Mirror sketch, produces an empty new sketch and a pop up error message "can't find property" OS: Ubuntu 14.04.3 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.5841 (Git) Build type: Release Branch: master Hash: e7d16c5f620bc4ddded8b8eae97d6e29c0012490 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
| Steps To Reproduce | Create a new document, new sketch on default plane xy, sketch an "L" or any other shape, constrain or don't makes not difference, close sketch edit mode, then select mirror sketch. An error box pops up saying "can't find property" and a new empty sketch is created. Help forum post where this was discovered http://forum.freecadweb.org/viewtopic.php?f=3&t=13015#p104260 | ||||
FreeCAD: master 501fa80e 2015-12-04 14:49:40 Committer: wmayer Details Diff |
Sketcher: Fix Sketch Mirror functionality ========================================= The problem: Mirror stopped working. How to reproduce: Select a sketch, and apply "Mirror Sketch" from the menu. Why? With the introduction of expressions, mirror sketch stopped working. The reason is that mirror functionality did use the "clone" function to make copies of constraints and then modify their values. After expessions introduction, which introduces a unique tag per constraint, this copy was regarded as a "rename" of the original constraint as they shared the unique tag. Fix? New function "copy()" for a constraint, that copies all the content but the tag. |
Affected Issues 0002315 |
| mod - src/Mod/Sketcher/App/Constraint.cpp | Diff File | ||
| mod - src/Mod/Sketcher/App/Constraint.h | Diff File | ||
| 2015-10-29 15:14 | jmaustpc | New Issue | |
| 2015-10-29 15:14 | jmaustpc | Status | new => assigned |
| 2015-10-29 15:14 | jmaustpc | Assigned To | => abdullah |
| 2015-12-09 12:56 | wmayer | Changeset attached | => FreeCAD Master master 501fa80e |
| 2015-12-09 12:56 | wmayer | Status | assigned => closed |
| 2015-12-09 12:56 | wmayer | Resolution | open => fixed |
| 2015-12-09 12:56 | wmayer | Fixed in Version | => 0.16 |
