0000232FreeCADFeaturepublic2011-09-17 12:47
Reporteryorik Assigned Toyorik
PrioritynormalSeverityminorReproducibilityN/A
Summary0000232: allow to draw line segments from angle+length
Descriptionallow to draw line segments from angle+length since last point
pperisin
2011-01-10 09:23
reporter   ~0000494
Hi,
Here you say "from angle+length since last point". Length can be from last point. but, IMHO, angle should not be from last placed line, but from horizontal line
Petar Perisin
yorik
2011-01-10 11:51
administrator   ~0000497
From last point can be useful too, this way you can for example easily draw a rectangle inclined 15°... Probably the best way is to keep the "Relative" button active, so you can switch between the 2.
pperisin
2011-01-12 15:06
reporter   ~0000507
OK. But then make relative only angle. IMO Length should always be relative.
Regards,
Petar Perisin
yorik
2011-09-17 12:47
administrator   ~0001113
I'll cancel this RFE, since the sketcher does it pretty well now (set a construction horizontal line, then set an angle constraint), and it becomes a bit obsolete to add it to the Draft module... But if someone disagrees, don't hesitate to reopen.
2011-01-08 13:32 yorik New Issue
2011-01-08 13:32 yorik Status new => assigned
2011-01-08 13:32 yorik Assigned To => yorik
2011-01-10 09:23 pperisin Note Added: 0000494
2011-01-10 11:51 yorik Note Added: 0000497
2011-01-12 15:06 pperisin Note Added: 0000507
2011-09-17 12:47 yorik Note Added: 0001113
2011-09-17 12:47 yorik Status assigned => closed
2011-09-17 12:47 yorik Resolution open => won't fix
