| 0002321 | FreeCAD | Bug | public | 2015-11-01 05:29 | 2015-12-15 13:15 |
| Reporter | Fat-Zer | Assigned To | wmayer | ||
| Priority | urgent | Severity | tweak | Reproducibility | always |
| Summary | 0002321: Build failure on current (71be79e) master | ||||
| Description | There is a build failure when building without FREECAD_USE_PCL obviously caused by 212e2bf. | ||||
| Additional Information | The snipp of build message: [ 73%] Building CXX object src/Mod/ReverseEngineering/App/CMakeFiles/ReverseEngineering.dir/BSplineFitting.cpp.o cd /tmp/FreeCAD_trunk-build/src/Mod/ReverseEngineering/App && /usr/bin/c++ -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DQT_CORE_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_OPENGL_LIB -DQT_SVG_LIB -DQT_UITOOLS_LIB -DQT_WEBKIT_LIB -DQT_XML_LIB -DReverseEngineering_EXPORTS -D_OCC64 -Wall -Wno-deprecated -Wno-write-strings -D_OCC64 -g -DFC_DEBUG -fPIC -I/tmp/FreeCAD_trunk-build -isystem /usr/include/qt4 -isystem /usr/include/qt4/QtOpenGL -isystem /usr/include/qt4/QtSvg -isystem /usr/include/qt4/QtUiTools -isystem /usr/include/qt4/QtWebKit -isystem /usr/include/qt4/QtGui -isystem /usr/include/qt4/QtXml -isystem /usr/include/qt4/QtNetwork -isystem /usr/include/qt4/QtCore -I/tmp/FreeCAD_trunk-build/src -I/home/alexander/projects/free-cad_code/src -I/usr/lib64/opencascade-6.8.0/ros/lin/inc -I/usr/include/python2.7 -I/usr/include/eigen3 -o CMakeFiles/ReverseEngineering.dir/BSplineFitting.cpp.o -c /home/alexander/projects/free-cad_code/src/Mod/ReverseEngineering/App/BSplineFitting.cpp /home/alexander/projects/free-cad_code/src/Mod/ReverseEngineering/App/BSplineFitting.cpp:101:24: error: missing binary operator before token "(" #if PCL_VERSION_COMPARE(>=,1,7,0) The status of bug is high due to it's a build-time issue. Please fix at as soon as possible. | ||||
Adding -DFREECAD_USE_PCL=ON results in another build failure: [ 73%] Building CXX object src/Mod/ReverseEngineering/App/CMakeFiles/ReverseEngineering.dir/BSplineFitting.cpp.o cd /tmp/FreeCAD_trunk-build/src/Mod/ReverseEngineering/App && /usr/bin/c++ -DDISABLE_OPENNI -DDISABLE_OPENNI2 -DDISABLE_PCAP -DDISABLE_PNG -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DHAVE_PCL_SURFACE -DQT_CORE_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_OPENGL_LIB -DQT_SVG_LIB -DQT_UITOOLS_LIB -DQT_WEBKIT_LIB -DQT_XML_LIB -DReverseEngineering_EXPORTS -D_OCC64 -DvtkRenderingCore_AUTOINIT="3(vtkInteractionStyle,vtkRenderingFreeType,vtkRenderingOpenGL)" -Wall -Wno-deprecated -Wno-write-strings -Wno-deprecated -D_OCC64 -g -DFC_DEBUG -fPIC -I/tmp/FreeCAD_trunk-build -I/usr/include/vtk-6.1 -I/usr/include/jsoncpp -I/usr/include/libxml2 -I/usr/include/freetype2 -isystem /usr/include/qt4 -isystem /usr/include/qt4/QtOpenGL -isystem /usr/include/qt4/QtSvg -isystem /usr/include/qt4/QtUiTools -isystem /usr/include/qt4/QtWebKit -isystem /usr/include/qt4/QtGui -isystem /usr/include/qt4/QtXml -isystem /usr/include/qt4/QtNetwork -isystem /usr/include/qt4/QtCore -I/tmp/FreeCAD_trunk-build/src -I/home/alexander/projects/free-cad_code/src -I/usr/lib64/opencascade-6.8.0/ros/lin/inc -I/usr/include/python2.7 -I/usr/include/eigen3 -I/usr/include/pcl-1.7 -o CMakeFiles/ReverseEngineering.dir/BSplineFitting.cpp.o -c /home/alexander/projects/free-cad_code/src/Mod/ReverseEngineering/App/BSplineFitting.cpp /home/alexander/projects/free-cad_code/src/Mod/ReverseEngineering/App/BSplineFitting.cpp:44:55: fatal error: pcl/surface/on_nurbs/fitting_surface_tdm.h: No such file or directory # include <pcl/surface/on_nurbs/fitting_surface_tdm.h> ^ sci-libs/pcl-1.7.2 on gentoo doesn't provides that file nor directory "on_nurbs" at all... |
| 2015-11-01 05:29 | Fat-Zer | New Issue | |
| 2015-11-01 05:46 | Fat-Zer | Note Added: 0006512 | |
| 2015-11-01 17:08 | wmayer | Changeset attached | => FreeCAD Master master caec2d98 |
| 2015-11-01 17:08 | wmayer | Assigned To | => wmayer |
| 2015-11-01 17:08 | wmayer | Status | new => closed |
| 2015-11-01 17:08 | wmayer | Resolution | open => fixed |
