| 0002322 | FreeCAD | Bug | public | 2015-11-01 09:42 | 2016-01-19 02:06 |
| Reporter | lanciaux | Assigned To | yorik | ||
| Summary | 0002322: Crash in updating/opening files in Assembly2 workbench due to recent changes in FreeCAD function open() after commit 969b43b | ||||
| Description | Assembly2 workbench is not working at once you do a second import or do any update of an assembly of at least 2 components in function "importpart" of importpart.py if filename.lower().endswith('.fcstd'): => this fails ! doc = FreeCAD.open(filename) * Abort *** an exception was raised, but no catch was found. ... The exception is:SIGSEGV 'segmentation violation' detected. Address ... | ||||
| Additional Information | It appears after FreeCAD commit "969b43b" | ||||
The assembly2 workbench is not part of FreeCAD, it's an independent project, and it has its own issues tracker. Please report this bug on the assembly2 project itself: https://github.com/hamish2014/FreeCAD_assembly2/issues Thanks! |
It has already been notified on Assembly2 workbench git bug tracker. We do not have understood differences made starting 969b43b on FreeCAD github. I and others will stop updating FreeCAD until it got fixed. Yours Ludovic (Belgium) |
I'm absolutely sorry to hear that, but it doesn't change our position. That commit extends the App.setActiveDocument/App.getDocument function to allow it to receive a python document object instead of a string. It doesn't change anything else, AFAICS. This change seems valid to me, I don t see any reason why it should not exist, and it is apparently working without problems. Unless you can show me there is a bug in freecad, and not in assembly2, I don t see anything we need to do here... |
Ludovic, thanks for creating the bug report. Yorik, thanks for your response. Furthermore, a big thanks to you and the FreeCAD team for the excellent work you do! I agree that you are not responsible for patching assembly 2. The assembly 2 issue is logged at https://github.com/hamish2014/FreeCAD_assembly2/issues/59 The reasons Ludovic and I suspect the this is a bug in FreeCAD and not assembly 2 are: 1) the crash occurs in Assembly2 code. importPart.py. which was last altered on the 10th of September, one Month before the crashes began occurring, and 2) conducted tests show the crashes began after the changes in FreeCAD described in https://github.com/FreeCAD/FreeCAD/commit/969b43bb64b5241ede622a6872b59cabce346fa6 That said, the code in assembly2/importPart.py could have been using the FreeCAD openDocument and closeDocument in a manner they were never intended to be used... Anyway to replicate the crash, open FreeCAD and run the following from the FreeCAD console def importPart( filename ): currentDoc = FreeCAD.ActiveDocument.Name FreeCAD.Console.PrintMessage("opening %s\n" % filename) doc = FreeCAD.openDocument(filename) FreeCAD.Console.PrintMessage("successfully opened\n") FreeCAD.setActiveDocument(currentDoc) #comment out to stop crashing ... # copy data from doc FreeCAD.closeDocument(doc.Name) importPart('/tmp/a.fcstd') # freecad file containing a cube importPart('/tmp/b.fcstd') # freecad file containing a cylinder In FreeCAD 0.16, Libs: 0.16R5667 (Git) this does not cause a crash .. |
Update, rewrote assembly2.importPart.py to work around issue. So non-urgent ... |
Thanks for the additional info hamish However, executing your example code above doesn't crash for me... If there is no active document opened when running the function, it stops at the first line, obviously. If there is one, the function can be ran any number of times without crashing. I don't know how is your assembly2 code, but I would suggest making this kind of function stronger, by always testing if there is an active document before doing things with it, etc. |
Verbose steps to reproduce crash on Linux system: Launch FreeCAD from Bash, and then paste the following into the Python console App.newDocument("Unnamed") App.setActiveDocument("Unnamed") App.ActiveDocument=App.getDocument("Unnamed") Gui.ActiveDocument=Gui.getDocument("Unnamed") App.getDocument("Unnamed").saveAs("/tmp/a.fcstd") App.getDocument("Unnamed").saveAs("/tmp/b.fcstd") App.closeDocument("Unnamed") App.setActiveDocument("") App.ActiveDocument=None Gui.ActiveDocument=None App.newDocument("Unnamed") App.setActiveDocument("Unnamed") App.ActiveDocument=App.getDocument("Unnamed") Gui.ActiveDocument=Gui.getDocument("Unnamed") def importPart( filename ): currentDoc = FreeCAD.ActiveDocument.Name FreeCAD.Console.PrintMessage("opening %s\n" % filename) doc = FreeCAD.openDocument(filename) FreeCAD.Console.PrintMessage("successfully opened\n") FreeCAD.setActiveDocument(currentDoc) #comment out to stop crashing ... # copy data from doc FreeCAD.closeDocument(doc.Name) importPart('/tmp/a.fcstd') importPart('/tmp/b.fcstd') |
I wanted to apologize a bit my words since Hamish has managed to fix the way he was importing files to accomodate changes to FreeCAD code. I now have updated sources to most recent modifications as workbench assembly2 is fully running again. |
Ah I see where the problem lies, hamish. Indeed your last code above causes a crash. When opening a new document, if there is an empty document opened already, it gets closed automatically. This happens in your function, and therefore, when trying to set the active document, currentDoc refers to a document name that doesn't exist anymore. Normally this gives an error, but not a crash: App.newDocument("somename") App.closeDocument("somename") App.setActiveDocument("somename") Maybe there is some race condition occurring in your function... Not easy to debug in any case. Probably better to always test that a document name exists before, for ex. with App.listDocuments() |
I think this can be closed? Or is there anything you think should be done here hamish? |
Hi Yorik, I am happy. You are welcome to close the issue. |
A good bug is a closed bug :) |
| 2015-11-01 09:42 | lanciaux | New Issue | |
| 2015-11-01 13:42 | yorik | Note Added: 0006514 | |
| 2015-11-01 13:42 | yorik | Status | new => closed |
| 2015-11-01 13:42 | yorik | Assigned To | => yorik |
| 2015-11-01 13:42 | yorik | Resolution | open => no change required |
| 2015-11-01 14:46 | lanciaux | Note Added: 0006515 | |
| 2015-11-01 14:46 | lanciaux | Status | closed => feedback |
| 2015-11-01 14:46 | lanciaux | Resolution | no change required => reopened |
| 2015-11-01 15:01 | yorik | Note Added: 0006516 | |
| 2015-11-02 07:57 | hamish2014 | Note Added: 0006517 | |
| 2015-11-02 07:59 | hamish2014 | Note Edited: 0006517 | |
| 2015-11-02 08:25 | hamish2014 | Note Added: 0006519 | |
| 2015-11-02 15:47 | yorik | Note Added: 0006520 | |
| 2015-11-02 17:26 | hamish2014 | Note Added: 0006521 | |
| 2015-11-11 20:01 | lanciaux | Note Added: 0006538 | |
| 2015-11-11 20:01 | lanciaux | Status | feedback => assigned |
| 2015-12-02 13:21 | yorik | Note Added: 0006573 | |
| 2016-01-03 19:03 | yorik | Note Added: 0006662 | |
| 2016-01-03 19:03 | yorik | Status | assigned => feedback |
| 2016-01-04 06:55 | hamish2014 | Note Added: 0006665 | |
| 2016-01-04 11:11 | yorik | Note Added: 0006667 | |
| 2016-01-04 11:12 | yorik | Status | feedback => closed |
| 2016-01-04 11:12 | yorik | Resolution | reopened => no change required |
