| 0002327 | PartDesign | Bug | public | 2015-11-03 09:32 | 2015-11-29 15:35 |
| Reporter | plastikos | Assigned To | jmaustpc | ||
| Platform | Linux amd64 | OS | Debian | OS Version | stretch/sid |
| Summary | 0002327: "Removing splitter failed" | ||||
| Description | This is really 0.16 (git 212e2bf19c24f94a5b359a3d3701f335fb006777) but this bug is in 0.15. Padding a circle using "Two dimensions" fails when base part has tangential edges to the circle. | ||||
| Steps To Reproduce | Use the attached file "splitter_bug.fcstd" 1) Create a plate with radii instead of corners (plate_solid) 2) Map a sketch to a face of the plate (standoffs_sketch) 3) Add a circle of the same radius as one of the plate radii flush to the plate radius 4) Pad the circle sketch (standoffs_sketch) using "Two dimensions" ("1 in" for both "Length" and "2nd Length" - total of "2 in") 5) The operation will fail with the message "Removing splitter failed" | ||||
this is fixed in occt 6.9.1. |
I'm using liboce 0.16. |
@ plastikos please in the first instance, always discuss matters in the forums where more people see it and can resolve the matter. Once we decide its a bug then post a ticket. I have no problems here. As you can see I have a later OCE, your OCE version is obsolete. Thanks for taking the time to post this but please next time discuss it in the forums first. OS: Ubuntu 14.04.3 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.5970 (Git) Build type: Release Branch: master Hash: 19c840e1ab299cb94ed534d5be61a95a5fac8691 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 |
This appears to be an OCE bug, the reporter's OCE version was obsolete. The error does not seem to appear with later OCE versions. |
| 2015-11-03 09:32 | plastikos | New Issue | |
| 2015-11-03 09:32 | plastikos | File Added: splitter_bug.fcstd | |
| 2015-11-14 21:08 | tanderson69 | Note Added: 0006544 | |
| 2015-11-16 09:55 | plastikos | Note Added: 0006545 | |
| 2015-11-29 15:32 | jmaustpc | Note Added: 0006561 | |
| 2015-11-29 15:35 | jmaustpc | Note Added: 0006562 | |
| 2015-11-29 15:35 | jmaustpc | Status | new => closed |
| 2015-11-29 15:35 | jmaustpc | Assigned To | => jmaustpc |
| 2015-11-29 15:35 | jmaustpc | Resolution | open => unable to reproduce |
| 2015-11-29 15:35 | jmaustpc | Fixed in Version | => 0.16 |
