| 0002330 | FreeCAD | Bug | public | 2015-11-05 12:07 | 2015-11-28 16:26 |
| Reporter | atreyu | Assigned To | yorik | ||
| Platform | freeCAD | OS | linux | OS Version | ubuntu 15.04 |
| Summary | 0002330: Unable to load drawings | ||||
| Description | When language is set to Spanish, drawings with wedges are lost after saving. | ||||
| Steps To Reproduce | Set language to Spanish. Draw a Wedge. Save the drawing. Close freeCAD. Open freeCAD. Load the drawing. Nothing appears and the dimensions of the wedge went to default. | ||||
| Additional Information | Only detected: -in Spanish -with Wedge Please find attached anomalous drawing. | ||||
I cannot reproduce this problem... Following the steps above works normally, as well as opening the attached file, although the encoding of that file (Document.xml) seems wrong (text editor says iso9951, although the xml header says utf8), so the ñ of label "cuña" renders wrongly In any case, your version of FreeCAD (0.14) is very old... The problem is apparently solved since long. We have a PPA with much more recent versions (0.15 in stable PPA and 0.16 in daily PPA). If you want to try these versions, your problem will apparently be gone then. Look on the freecad wiki for instructions. |
Yes, you are right. After upgrading to 0.16, there is no problem. |
| 2015-11-05 12:07 | atreyu | New Issue | |
| 2015-11-05 12:07 | atreyu | File Added: 1.fcstd | |
| 2015-11-05 19:17 | yorik | Note Added: 0006531 | |
| 2015-11-05 19:17 | yorik | Assigned To | => yorik |
| 2015-11-05 19:17 | yorik | Status | new => feedback |
| 2015-11-05 22:55 | atreyu | Note Added: 0006532 | |
| 2015-11-05 22:55 | atreyu | Status | feedback => assigned |
| 2015-11-28 16:26 | yorik | Status | assigned => closed |
| 2015-11-28 16:26 | yorik | Resolution | open => no change required |
| 2015-11-28 16:26 | yorik | Fixed in Version | => 0.16 |
