| 0002335 | File formats | Feature | public | 2015-11-12 08:43 | 2021-02-06 06:31 |
| Reporter | douardda | Assigned To | |||
| Summary | 0002335: export in .obj file should use the objects labels | ||||
| Description | When exporting objects in a Wavefront .obj file format, the object labels are not used to identify them in the generated file, but are generated from the object type. eg. a scene with a cube named 'MonCube' in FreeCad will be exported as: # FreeCAD v0.15 build4671 (Git) Arch module # http://www.freecadweb.org o Box v 18.881188 4.8209 4.903852 v 18.881188 4.8209 -5.096148 v 18.881188 14.8209 4.903852 v 18.881188 14.8209 -5.096148 v 28.881188 4.8209 4.903852 v 28.881188 4.8209 -5.096148 v 28.881188 14.8209 4.903852 v 28.881188 14.8209 -5.096148 f 1 2 4 3 f 5 6 8 7 f 6 2 1 5 f 8 4 3 7 f 4 2 6 8 f 3 1 5 7 I would have expected the line: o Box to be: o MonCube | ||||
| Tags | #post-to-forum, OBJ | ||||
| related to | 0002336 | new | importing .obj file should use the object names as labels |
Hello douardda: I wrote a solution in https://github.com/caceres/FreeCAD/commits/importOBJ commit 21 nov 2015 "enable obj Label" |
@damian did you submit a PR for this? BTW the repo link is 404 |
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=10&t=20088 |
@damian ping |
This ticket has been migrated to GitHub as issue 5635. |
| 2015-11-12 08:43 | douardda | New Issue | |
| 2015-11-25 13:41 | damian | Note Added: 0006553 | |
| 2015-11-25 16:30 | damian | Note Edited: 0006553 | |
| 2015-11-28 16:08 | wmayer | Relationship added | related to 0002336 |
| 2017-01-16 09:55 | Kunda1 | Note Added: 0007818 | |
| 2017-01-16 09:55 | Kunda1 | Status | new => feedback |
| 2017-01-20 21:36 | Kunda1 | Note Added: 0007897 | |
| 2017-03-02 12:16 | Kunda1 | Note Added: 0008509 | |
| 2017-03-20 22:38 | Kunda1 | Tag Attached: OBJ | |
| 2018-01-25 16:54 | Kunda1 | Category | => Feature |
| 2018-01-25 16:54 | Kunda1 | Tag Attached: #post-to-forum | |
