| 0002341 | File formats | General | public | 2015-11-17 14:08 | 2015-12-02 20:47 |
| Reporter | lepalom | Assigned To | yorik | ||
| Platform | Linux Amd64 | OS | Debian | OS Version | Jessie |
| Summary | 0002341: Exporting dae makes freecad crash | ||||
| Description | Using 0.16_pre, exporting a Collada makes that Freecad eat a lot of memory and finally crash. | ||||
| Steps To Reproduce | Open the file, select the object and export to Collada | ||||
There are indeed some problems with exporting heavy objects to collada... I'll have a better look at this |
I am now committing a change that allow to use the full range of FreeCAD-supported meshers in Collada export. This should solve problems with shapes that fail to mesh with the builtin mesher. However, the attached shape appears to be quite problematic, none of the meshers manage to mesh it... |
| 2015-11-17 14:08 | lepalom | New Issue | |
| 2015-11-17 14:08 | lepalom | File Added: base.fcstd | |
| 2015-11-17 17:32 | yorik | Note Added: 0006547 | |
| 2015-11-17 17:32 | yorik | Assigned To | => yorik |
| 2015-11-17 17:32 | yorik | Status | new => assigned |
| 2015-12-02 20:47 | yorik | Note Added: 0006574 | |
| 2015-12-02 20:47 | yorik | Changeset attached | => FreeCAD Master master 1acf4870 |
| 2015-12-02 20:47 | yorik | Status | assigned => closed |
| 2015-12-02 20:47 | yorik | Resolution | open => fixed |
