0002362FreeCADBugpublic2015-12-15 13:15
ReporterChapaikinVA Assigned Toyorik
PrioritynormalSeveritymajorReproducibilitysometimes
Fixed in Version0.16
Summary0002362: Bug with a Common: is not computed properly
DescriptionA ununderstandable bug: Common is not computed properly.
See a pic.
Additional InformationOS: Ubuntu 14.04.3 LTS
Version: 0.16.6032 (Git)
Build type: None
Hash: dde207c360e0d27c90347f9c563b859e7023e1b8
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
ChapaikinVA
2015-12-11 02:27
reporter
Bug_Common_2015-12-11 08:08:07.fcstd (Attachment missing)
ChapaikinVA
2015-12-11 02:27
reporter
yorik
2015-12-13 14:50
administrator   ~0006602
This might be considered a bug in opencascade, but I'm afraid there is not much we can do on the FreeCAD side... Try to avoid doing booleans on compound objects, it will have more chances to succeed if you work with single solids one at a time.
I'll close this report because I don't see anything we can do, reopen if needed.
2015-12-11 02:27 ChapaikinVA New Issue
2015-12-11 02:27 ChapaikinVA File Added: Bug_Common_2015-12-11 08:08:07.fcstd
2015-12-11 02:27 ChapaikinVA File Added: 032.png
2015-12-13 14:50 yorik Note Added: 0006602
2015-12-13 14:50 yorik Status new => closed
2015-12-13 14:50 yorik Assigned To => yorik
2015-12-13 14:50 yorik Resolution open => not fixable
2015-12-15 13:15 yorik Fixed in Version => 0.16
