| 0002365 | FreeCAD | Bug | public | 2015-12-11 23:17 | 2016-01-21 16:25 |
| Reporter | hardman | Assigned To | jmaustpc | ||
| Platform | mac | OS | OS X 10;11;2 | OS Version | 10;11;2 |
| Summary | 0002365: OPTIONS OF SAVE ARE INVISIBLE | ||||
| Description | CAN NOT SELECT THE BACKUP OPTIONS | ||||
| Steps To Reproduce | creation of a 3D object select the object File -> Export backup window (bug selectio for the .STL format) | ||||
| Additional Information | the format is necessary for printing 3D | ||||
What is the FreeCAD version? Where did you take it from? |
In FreeCAD we do not use any OSX specific code to show the file dialog but we rely on Qt on this. Maybe Qt has a bug there. It would be good to use any other Qt-based application on OSX to see whether it shows the same behaviour. |
a month with no reply, another case that would have been better if discussed in the Help forum first. This can't be taken seriously without further information, for example no FreeCAD version data. I will close it for now, we can reopen it if it turns out to be related to a current FreeCAD version. |
| 2015-12-11 23:17 | hardman | New Issue | |
| 2015-12-11 23:17 | hardman | File Added: bug freecad.tif | |
| 2015-12-13 14:35 | yorik | Priority | immediate => normal |
| 2015-12-13 14:38 | yorik | Note Added: 0006600 | |
| 2015-12-13 14:45 | yorik | Status | new => feedback |
| 2015-12-16 18:36 | wmayer | Note Added: 0006613 | |
| 2016-01-21 16:24 | jmaustpc | Note Added: 0006746 | |
| 2016-01-21 16:24 | jmaustpc | Status | feedback => closed |
| 2016-01-21 16:25 | jmaustpc | Assigned To | => jmaustpc |
| 2016-01-21 16:25 | jmaustpc | Resolution | open => no change required |
