| 0002368 | FreeCAD | Bug | public | 2015-12-12 21:37 | 2016-01-21 15:30 |
| Reporter | ChapaikinVA | Assigned To | jmaustpc | ||
| Platform | Linux | OS | Ubuntu | OS Version | 14.04 x64 |
| Summary | 0002368: A fusion is not displayed | ||||
| Description | Fusion001 object is not displayed but it has an icon as if the object is calculated properly. If to change Sketch001, the icon changes to "!" ("Error"). | ||||
| Steps To Reproduce | 1. Open the file. 2. Open Sketch001. 3. Move the ellipse. 4. Close sketch editor. | ||||
| Additional Information | OS: Ubuntu 14.04.3 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6039 (Git) Build type: None Branch: master Hash: 3dcc557e65897d25eee0d27c2ececc95351fea79 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
no problem for me, I can move the ellipse and the fusion gets recomputed correctly.. |
Re-check as described below, please. Steps To Reproduce: 1. Open the file. 2. Open Sketch001. 3. Move the ellipse: Do a very little movement (eg., 1 mm). If I move the ellipse so that it become fully outside other solid object ("Clone of Fusion"), I also do not get an error. But if I move the ellipse that it partially intersects the solid object "Clone of Fusion", I get an error on computation of a fusion as I have described previously. 4. Close sketch editor. |
Please always post to the Help forum first before making a bug ticket so that we can keep the ticket numbers to a minimum and keep their quality as high as possible. I have tried with both the versions below and I can not reproduce what you describe, although when I first open the file Fusion001 is not visible/has not been computed, presumably due to some error or other in your FreeCAD/model, but when I force a recompute it works for me. There are several possible problems with your file. Please feel free to post this in the Help forum where more will see it and work out what is happening. We can re-open this bug ticket if needed but I think I will close it for now. OS: Ubuntu 12.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6245 (Git) Build type: Debug Branch: master Hash: ebc6d37262f1b07358351e336fa480f135baa240 Python version: 2.7.3 Qt version: 4.8.2 Coin version: 3.1.3 OCC version: 6.9.1.oce-0.18-dev OS: Ubuntu 12.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6205 (Git) Build type: Debug Branch: master Hash: 89cb2479232ea949b368e849d90fd6ce563154c1 Python version: 2.7.3 Qt version: 4.8.2 Coin version: 3.1.3 OCC version: 6.8.0.oce-0.18-dev |
| 2015-12-12 21:37 | ChapaikinVA | New Issue | |
| 2015-12-12 21:37 | ChapaikinVA | File Added: Bug__Union_failed.2015-12-13 03:25:18.fcstd | |
| 2015-12-13 14:44 | yorik | Note Added: 0006601 | |
| 2015-12-13 14:45 | yorik | Status | new => feedback |
| 2015-12-14 21:16 | ChapaikinVA | Note Added: 0006609 | |
| 2015-12-14 21:16 | ChapaikinVA | Status | feedback => new |
| 2015-12-14 21:17 | ChapaikinVA | Note Edited: 0006609 | |
| 2015-12-14 21:18 | ChapaikinVA | Note Edited: 0006609 | |
| 2016-01-21 15:29 | jmaustpc | Note Added: 0006742 | |
| 2016-01-21 15:30 | jmaustpc | Status | new => closed |
| 2016-01-21 15:30 | jmaustpc | Assigned To | => jmaustpc |
| 2016-01-21 15:30 | jmaustpc | Resolution | open => unable to reproduce |
