| 0002374 | PartDesign | Bug | public | 2015-12-23 15:07 | 2016-01-21 15:07 |
| Reporter | pchecko | Assigned To | jmaustpc | ||
| Summary | 0002374: Bug using linear pattern tool on pocket with draft or fillets | ||||
| Description | A bug occurs when using the linear pattern tool for a pocket that has draft or fillets. | ||||
| Steps To Reproduce | Correct operation: 1. Pad a rectangle to create a long rectangular block. 2. Pocket a small rectangular hole either through-all or partial. 3. Create a linear pattern of several pockets. The above actions produce a normal result of several identical pockets in the base block spread out by the specified parameters. Bug: 1. Go back to a single pocket. 2. Add draft to the walls of the pocket to make the base smaller than the opening. Or add a fillet to the base of the pocket. 3. Create a linear pattern with this pocket. The result is that just the original pocket is shown correctly. The additional pockets appear as a rectangle on the surface, but they do not have any depth. The expected behavior is the same as the correct operation presented above. | ||||
| Additional Information | I left the severity of this as minor, because it could be worked-around by a one-by-one process. However, I'm working on a design where I want 100 pockets, so not having this feature work correctly is a major issue for me. Thanks for your help. I'm beginning to like this a lot more than TinkerCAD. | ||||
Thank you for your time creating this bug ticket, but this matter would have been much better and faster dealt with, if posted to the Help forum. Please always in the future first post to the Help forum so as to keep the number of unneeded ticket to a minimum and keep the quality as high as possible. This is all a known limitation of the current PartDesign Pattern features that is or will be dealt with in/after the "PartDesign next" code is pushed to master after 0.16 is released. |
