| 0002379 | FreeCAD | Bug | public | 2015-12-27 21:07 | 2016-02-13 13:37 |
| Reporter | edman007 | Assigned To | jmaustpc | ||
| Priority | normal | Severity | crash | Reproducibility | sometimes |
| OS | Slackware | OS Version | current | ||
| Summary | 0002379: Crash when sweeping | ||||
| Description | When sweeping over a cross section of my part (with some admittedly sharp corners) FreeCAD usually crashes, it should work or error give me an error if there is a problem. | ||||
| Steps To Reproduce | In the attached fcstd file, sweep the OuterGasketk over the HullFlangePath, select the path, starting with the straight line that touches the sketch, and going around selecting all wires in HullFlangePath FreeCAD crashes, it usually crashes, sometimes it errors out. | ||||
| Additional Information | Using OpenCASCADE 6.9.1 and FreeCAD git e983479 (yesterday I beleive), 64-bit linux. | ||||
Please discuss all the issues you find on the Help forum before you create a bug ticket so as to reduce the number and increase the quality of bug tickets. No crash here, is there any chance you have updated/changed your OCC version and FreeCAD was compile against a different OCC version? OS: Ubuntu 12.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6245 (Git) Build type: Debug Branch: master Hash: ebc6d37262f1b07358351e336fa480f135baa240 Python version: 2.7.3 Qt version: 4.8.2 Coin version: 3.1.3 OCC version: 6.9.1.oce-0.18-dev |
looks like an issue better discussed in the Help forum, |
| 2015-12-27 21:07 | edman007 | New Issue | |
| 2015-12-27 21:07 | edman007 | File Added: short-hull-param.fcstd | |
| 2015-12-27 21:07 | edman007 | File Added: freecad-bt1.txt | |
| 2015-12-27 21:07 | edman007 | File Added: freecad-bt2.txt | |
| 2016-01-21 17:24 | jmaustpc | Note Added: 0006751 | |
| 2016-02-13 13:37 | jmaustpc | Note Added: 0006831 | |
| 2016-02-13 13:37 | jmaustpc | Status | new => closed |
| 2016-02-13 13:37 | jmaustpc | Assigned To | => jmaustpc |
| 2016-02-13 13:37 | jmaustpc | Resolution | open => unable to reproduce |
