| 0002385 | FreeCAD | Feature | public | 2015-12-31 08:38 | 2016-01-09 16:03 |
| Reporter | piffpoof | Assigned To | wmayer | ||
| Platform | Macintosh | OS | Mac OS X | OS Version | 10.6.8 |
| Summary | 0002385: unable to set value higher than 99.99 on Distance value in Part->Cross Sections | ||||
| Description | I am attempting to generate 7 cross-sections in a 4m wide model - so about 60cm spacing between cross-sections. The input box will only allow 99.99 with the default unit of mm - so about 10cm maximum distance. I have achieved what I wanted using Python but users limited to the GUI would not be able to do so. A forum thread on this is at: http://forum.freecadweb.org/viewtopic.php?f=3&t=13687 | ||||
| Steps To Reproduce | Part WB->Cross Sections Click the Sections checkbox The Distance field will be enabled with a value of 99.99 This value can not be increased. Also if the Count value is greater than 11 the Distance value will start to be decreased. | ||||
| Additional Information | The code works fine from Python so most likely the "99.99" limit is a GUI issue only. | ||||
| 2015-12-31 08:38 | piffpoof | New Issue | |
| 2015-12-31 11:26 | wmayer | Changeset attached | => FreeCAD Master master ebbb68d9 |
| 2015-12-31 11:26 | wmayer | Assigned To | => wmayer |
| 2015-12-31 11:26 | wmayer | Status | new => closed |
| 2015-12-31 11:26 | wmayer | Resolution | open => fixed |
| 2015-12-31 11:26 | wmayer | Fixed in Version | => 0.16 |
