| 0002395 | FreeCAD | Feature | public | 2016-01-09 02:39 | 2016-02-23 14:21 |
| Reporter | ChapaikinVA | Assigned To | |||
| Summary | 0002395: General calculation on GPUs (OpenCL, CUDA etc) to make FreeCAD work faster | ||||
| Description | Implement an optional support of general calculation on GPUs (like via OpenCL), please. Now FreeCAD often (when recalculates a lot of changes) works very slowly. | ||||
I'm afraid this is not possible for us to do. All these calculations are done by OpenCasCade, FreeCAD's geometry kernel. Such request should be made to them at http://dev.opencascade.org/ |
I can submit them such feature request of course. But I am an end user, not a programmer. So now I do not understand even what exactly is OpenCASCADE at all and internally. So, it is possible that I'll not be understood properly. If somebody of FreeCAD team think that this feature request is desired, it migth be better, if he (instead of me) describe and post such report. |
opencascade is a piece of software that does 99% of all the geometrical calculations inside freecad. It's the "engine" of freecad. I honestly doubt it would be of any use to request that to them, because GPUs are tailored for mesh and rendering calculations, I don't think it can be of any use (at least today, maybe in the future) for solid geometry and nurbs, which is what we use mostly in freecad (and what generates all the heavy calculation) They would probably listen only if the contrary could be proved to them, but that would mean do quite a lot of research... Not sure there will be many volunteers Someone asked already... not much answer :) http://www.opencascade.com/content/gpu-acceleration |
Ok. __________ General calculation on GPUs is very powerful. I know it as I use BOINC projects on my PC. They use GPUs both integer and floating calculations. As I can see (there are two graphics cards on my PC) the performance of GPU applications is ~ 10 - 1000 (!!!) times higher than for CPU (4 cores, 1333 MHz) applications. |
I will close this issue, because there is AFAIK nothing to do on our side, don't hesitate to reopen if needed or have more info. |
| 2016-01-09 02:39 | ChapaikinVA | New Issue | |
| 2016-01-09 18:01 | yorik | Note Added: 0006699 | |
| 2016-01-09 18:43 | ChapaikinVA | Note Added: 0006702 | |
| 2016-01-09 18:59 | yorik | Note Added: 0006703 | |
| 2016-01-09 19:45 | ChapaikinVA | Note Added: 0006705 | |
| 2016-01-09 19:45 | ChapaikinVA | Note Edited: 0006705 | |
| 2016-02-23 14:21 | yorik | Note Added: 0006845 | |
| 2016-02-23 14:21 | yorik | Status | new => closed |
| 2016-02-23 14:21 | yorik | Resolution | open => no change required |
| 2016-02-23 14:21 | yorik | Fixed in Version | => 0.16 |
